Site that clearly explains transistors
  • Thread starter Thread starter logearav
    Transistors
This discussion focuses on the application of Kirchhoff's Voltage Law (KVL) in transistor circuits, specifically in understanding the Vbe and Vce loops. The user expresses confusion regarding the differences between analyzing transistor circuits and traditional circuits with batteries and resistors, such as Wheatstone's bridge. An example is provided, illustrating the Vbe loop in a circuit with a 9V source, a 470-ohm resistor, and an LED. A helpful resource is shared, which explains transistor circuits in detail.
  • Understanding of Kirchhoff's Voltage Law (KVL)
  • Basic knowledge of transistor operation and configurations
  • Familiarity with circuit components such as resistors and LEDs
  • Ability to read and interpret circuit diagrams
  • Research "Transistor circuit analysis techniques"
  • Study "Applying Kirchhoff's Voltage Law in transistor circuits"
  • Explore "Transistor characteristics and parameters" including Vbe and Vce
  • Review "Common transistor configurations and their applications"
Students studying electronics, educators teaching circuit analysis, and hobbyists working with transistor circuits will benefit from this discussion.
logearav
friends,
i have difficulty in applying KIRCHOFF VOLTAGE LAW in transistors. i am confused because it is totally different from circuits with batteries and resistances where finding the path of closed loop is easy say wheatstone's bridge.
but in transistor i cannot understand a statement like this " apply KVL TO Vbe loop or Vce loop.
can anyone give a link to a website which clearly explains these concepts?
help in this regard will be greatly appreciated
It means to say apply the KVL from the base to the emitter or from the collector to the emitter. Could you give an example of what confuses you?
both from base to emitter and also from collector to emitter. i am confused which is the starting point and the path. for example, which is positive and which is negative when i find Vbe and Vce.
Here, I just googled transistor circuit and clicked on one of the first websites, so here's a random example.
http://www.kpsec.freeuk.com/trancirc.htm
Look at that first transistor circuit, the one with LEDs. The Vbe loop goes from the 9V to 470 to LED C to vce to gnd. The Vbe loop goes from 9V to switch to led to vbe to gnd.
dear mr. mindscrape, thanks a ton for the link.
