Skateboarding Physics: Force of Landing from 10ft Roof
  • Context: Undergrad
  • Thread starter Thread starter kevshabar Reference
    Physics
The discussion centers on the physics of landing from a 10-foot roof while skateboarding, comparing two scenarios: one where the skateboarder rides off at 15 mph and another where they fall vertically at 0 mph. Key assumptions include no friction, synchronous landing of the skateboard's wheels, and consistent rider posture. The consensus is that the force exerted on the skateboarder's feet is likely greater in the vertical fall scenario due to the combined effects of horizontal and vertical deceleration upon landing.
  • Understanding of basic physics concepts, particularly force and motion.
  • Familiarity with the principles of deceleration and momentum.
  • Knowledge of skateboard dynamics and rider posture during landing.
  • Awareness of the effects of gravity on falling objects.
  • Research the physics of deceleration in vertical vs. horizontal falls.
  • Explore skateboard design and its impact on landing forces.
  • Study the biomechanics of shock absorption in athletes during falls.
  • Learn about energy transfer in collisions and impacts in sports physics.
Skateboarders, physics students, sports scientists, and anyone interested in the mechanics of falls and impacts in extreme sports.
kevshabar Reference
Which scenario would exert the most force on the skateboarders feet upon landing on the ground?
Scenario 1: Skateboarder rides skateboard 15 mph off of 10ft building roof
Scenario 2: Skateboarder falls directly vertical (0 mph) off of 10ft building roof
Assumptions:
-- no friction
-- maximum vertical fall distance is the same in both scenarios
-- roof and ground are level in both scenarios
UPDATE: (more assumptions)
-- board and rider remain in a horizontal (board) and upright (rider) position
-- rider lands with both feet on the board
-- board lands with all wheels coming in contact with the ground at the same time
-- rider's shock absorbing body movements are the same in both scenarios
Welcome to PF.
They will be the same, but in scenario 1, the front axle will start to fall first so axle impact with the ground will not be synchronous. The total deceleration time will be longer so the force can be less.
Sounds an awful lot like a homework problem, so why not show us your result first?
Meanwhile, there's no assumption that the guy is actually going to land feet-down. I mean, a skateboard under you is going to affect a fall since it cannot all go over the edge simultaneously.
It's actually a debate with my brothers, thanks for your concern though.
The answer will be rider, style, case and assumption dependent.
If the rider lands on their head there will be little force on their feet.
What assumptions are being made?
I would expect the rider to transfer weight to the rear axle as the front axle goes over the edge, so there will be less rotation of the board. The scenario results will then be similar.
If it goes wrong, the survivability will be greater with injury reduced in scenario 1, since the rider will be better able to land and roll like a parachutist. That will transfer vertical momentum into horizontal momentum more efficiently than in scenario 2, where energy must be dissipated in a small area.
@Baluncore we haven't even started debating about survivability yet.. 😂 I updated the original post with some more assumptions
Welcome to PF. :smile:
We need to know if it's schoolwork so we can be sure to keep such posts in the dedicated schoolwork forums. Hence the question. Thanks for your reply.
I hope you and your freinds are not contemplating trying this on a dare or bet or something. My teenage son did something almost similar from about 7 feet, and ended up with casts on both arms for a while (not a good scenario, for multiple reasons that was a very bad result).
I've flat-landed my MX dirtbikes from maybe 7-8 feet high a few times, and flat-landers are always uncomfortable. Much better to land on a down-slope, from no matter how high. :wink:
BTW, please try not to update your previous posts with new information -- that can be very confusing for otheres who are responding. Please instead just post a new reply. Thanks.
There can be no difference between the two scenarios if the goalposts are assumed to be in the same hole.
They should be the same because the x and y components are independent of each other and the force of the feet on the ground is in the y direction. The x component of the skateboarder riding 15 mph (x component) would not affect the y component.
The force is almost certainly greater in the second case, as you have horizontal as well as vertical deceleration on landing.
But there is no friction, so cannot decelerate horizontally.
There will be, once the skateboard shoots out from under and the posterior hits the sidewalk. [But OP specifically mentions "skateboarder's feet"]
  • Haha
The OP post #1 assumptions were extended.
Assumptions:
-- no friction
(more assumptions)
  • · Replies 65 ·
  • · Replies 16 ·
