What is the difference between slat and tile arrays in active phased arrays?
  • Thread starter Thread starter senmeis
    Arrays
The discussion clarifies the differences between slat and tile arrays in active phased arrays, emphasizing that the distinction primarily lies in the packaging of electronics on PCBs rather than the antennas themselves. Slat arrays utilize PCBs arranged edge-on to the array face, allowing for more electronic component space, while tile arrays position PCBs flat against the array face, reducing component space but lowering costs. Both types of arrays utilize antennas that radiate perpendicular to the array plane, with slat arrays potentially using printed dipoles and tile arrays using patch antennas.
  • Understanding of active phased array technology
  • Familiarity with PCB design and layout
  • Knowledge of antenna types, specifically patch and dipole antennas
  • Basic principles of electromagnetic radiation and antenna theory
  • Research the design principles of active phased arrays
  • Study the differences between patch antennas and printed dipole antennas
  • Explore PCB design techniques for RF applications
  • Learn about the electromagnetic radiation patterns of different antenna types
Engineers and researchers in the fields of telecommunications, radar technology, and antenna design, as well as anyone involved in the development of active phased array systems.
senmeis
Hi,
I’m reading the attached pdf article at https://www.microwavejournal.com/art...neration-radar about tile architecture in active phased arrays. Please help me with the following two questions.
1. Figure 2: Are this figure and the attached architecture (array.jpg) referred to the same structure?
2. It seems the radiating direction of the elements in tile arrays (Figure 3) is perpendicular to the plain. What about the radiating direction in slat arrays?
Senmeis
  • Tile Arrays Accelerate the Evolution to Next.pdf
It looks as if the difference between slat and tile arrays is nothing to do with the antenna itself but is concerned with the packaging of the electronics on to PCBs.
The slat array is an older system where the PCBs are arranged edge on to the face of the array, proving lots of space for electronics. The tile arrays use PCBs flat on the face of the array, so that there is much less component space but it is cheaper.
I’m not sure if the elements are the same. It seems to me the elements in Figure 2 are patch antennas which are perpendicular to the face of the array, but the elements in Figure 3 are parallel to the face of the array.
Sorry, I do not have access to the Microwave journal. It is possible the tile uses patch antennas and the slat uses printed dipoles.
This is correct, however both elements radiate perpendicular to the array plane.
The original article is already attached. I don’t understand why elements in Figure 3 radiate perpendicular to the array plane. I always think the radiating direction of patch antenna is parallel to the pad plane.
Because they are a metal surface approximately one-half wavelength that is mounted on a dielectric above a ground plane. It resonates and sets up big fields at its edges (from patch to ground plane). These fields resemble those from a slot radiator and launch radiation normal to the patch.
A patch resembles two slots cut in the ground plane. Each slot radiates over a complete 180 degree sector normal to its length. So you are right there is radiation along the ground plane. But as there are two slots, they form a broadside array with half wave spacing and the same phase, so they cancel radiation along the ground plane, leaving a maximum normal to the ground plane.
Likes marcusl
Incidentally, the radiation from a slot is caused when electrons in the metal are accelerated by the transmitter. The fields in the slot do not do the radiating.
Likes marcusl
  • · Replies 16 ·
11K
11K
