Sliding down the curved/straight slide
  • Thread starter Thread starter cloveryeah
    Slide Sliding
The discussion centers on the physics of two boys sliding down different types of slides: one curved and one straight, both starting from the same height. It is established that the boy on the curved slide reaches the bottom first due to the steeper initial descent, which allows for greater acceleration from gravity. The concept of the brachistochrone curve is introduced, indicating that the optimal path for minimizing descent time is a specific curve shape. The final velocities may be the same, but the time taken differs due to the varying distances and acceleration profiles of the slides.
  • Understanding of gravitational potential energy and kinetic energy (1/2 mv^2 = mgh)
  • Basic knowledge of acceleration and motion dynamics
  • Familiarity with the concept of the brachistochrone curve
  • Ability to analyze motion along different paths
  • Research the principles of the brachistochrone problem and its applications
  • Study the effects of different slide shapes on acceleration and time of descent
  • Explore the physics of potential and kinetic energy in different motion scenarios
  • Learn about the mathematical modeling of curves in physics
Students studying physics, educators teaching motion dynamics, and anyone interested in the principles of acceleration and energy conservation in real-world scenarios.
cloveryeah
a boy is sliding down a curved slide, another boy with same mass is sliding down a straight slide. if both slides have the same height, which of them will reach the bottom first?
i m thinking if it is related to 1/2 mv^2 = mgh
and final v will be the same in both cases
but how can i calculate the time required?
if the final velocity is not the same, speed is the same
one has a larger distance to cover, so it would take a different time to reach the ground.
"Even though it is longer than the other tracks, the curved slide is the quickest. This is because it is much steeper at the beginning, which means that gravity has a greater effect on the ball causing it to accelerate more quickly and reach its top speed sooner."
Also, what if the curve of the slide is a brachistochrone curve?
see this, it has the total explanation :http://www.qedcat.com/misc/94.html
In case it's not clear from Suraj's reply, there's not enough information. It depends on the details of the curve. However, there are some simple assumptions that can be made which allow an answer. For a start, it is obvious that if the curved slide starts off descending more slowly than the straight slide it can take longer, so assume that for any given horizontal distance from the start the curved slide is no higher than the straight slide.
  • · Replies 17 ·
  • · Replies 20 ·
