Small Liquid CO2 Manufacturing Machine?
8 replies · 15K views · last reply
Admin
At my work, we go through a lot of liquid CO2 (LCO2), and dealing with the 500 pound LCO2 dewars is a real pain. I'd like to look at options for us making our own LCO2 instead, but have been having trouble finding information about small-scale LCO2 generation on the web.
We use the LCO2 for rapid cooling in our reliability test ovens like the one below. The flow rates are not all that high (a 500 pound dewar can last ~ 24 hours with constant use), so I'm hopeful that some small/medium-sized machine can make the LCO2 that is needed for an oven or group of ovens.
Does anybody have any suggestions or links to vendors of small LCO2 making machines? Thanks.
http://www.emcgrath.com/catalog/images/OV/OVE422-1.jpg
As a point of clarification, do you mean to liquify pre-existing CO2, or create it from scratch with chemical reactions?
That's a great question, and it shows how much I guess I need to learn about this.
I'd naively thought of just getting the CO2 from the air in the lab, but I guess it would make sense that it would be a lot more efficient to start with CO2 gasses in bottles. Still, part of the hassle of the dewars is having to deal with refills and such.
What options do I have?
Do keep in mind that I don't know what the hell I'm talking about... but I love to speculate. :biggrin:
One option is that you could approach it from the opposite end and have dry ice shipped in. I see no advantage in doing that, though. In fact, it's probably far less efficient than gas.
Another is based upon my bartending experience. One of the places where I worked used a "carbonator" rather than bottled CO2 to make our pop. I don't know how it worked, specifically, but it was like a little compressor that sucked CO2 out of the air, compressed it, and force-mixed it with the flavour syrup. You can probably get some good information from a restaurant supply company. Specify a "carbonator pump" when inquiring, since the bottle systems are also called carbonators.
The next problem, of course, is your pressurization system, since you need something like 5 atmospheres to hold the stuff as a liquid.
The only thing I can think of is to start with a solid CO2 (dry ice) and use pressure to liquify it. Not that I know if it can be easily done, just the dry ice is the only other way of buying CO2 I know. (Edit: I am an idiot, it can be bought pressurized in bottles - but then you would need to cool it down, starting with the dry ice you at least have it already cold). Making it in amounts you need doesn't sound feasible - probably more hassle than moving these devars. And the amount in air is way too low for your needs - less than 1 g per cubic meter.
Hi berkeman, There's no need to make your own or have it delivered in cylinders. You can purchase it in bulk from most of the major industrial gas companies and from a host of smaller specialty industrial gas manufacturers. They pull up with a truck and offload it as a very cold liquid, similar to the delivery of gasoline, home heating oil, propane, etc...
Basically, you'll have a tank on your company's property that the industrial gas company delivers to. I'm not as familiar with CO2 but the tanks I've seen are generally insulated and have a refrigeration system on them to re-condense the gas as ambient heat boils off the liquid. You then have piping running through your facility to wherever you need it. Since it's similar to a cryogen, if you need the product as a liquid, the piping will probably be insulated and you'll need to cool down the line by flowing vapor through it till you can get the liquid coming out. Another option is to fill your own liquid cylinders at the tank and transport them to where they're needed.
I'd suggest contacting your supplier for CO2 as a starting point. The major industrial gas manufacturers include Praxair, Linde, Air Liquide, http://www.airproducts.co.uk/gases/carbon_dioxide.htm, BOC and http://www.airgas.com/content/details.aspx?id=7000000000317. I looked up a few of them as an example. Only some of them are likely to be available in the area you're in, and they'll typically know who's in your area. CO2, like other products, will be the least expensive from the supplier who has the least distance to travel for delivery, so when contacting these companies, you might try asking them what company is in your area because they don't all compete in all areas.
You could put your own system together with standard parts. They make very small cryogenic coolers for IR cameras that get below 80 K. Some weigh less than a pound.
Lockheed in Orlando makes several very nice ones for the military, but they use technical talent from nearby UCF. You might contact them for advice.
This could be an interesting design project.
Make sure you prepare an MSDS (mostly cut and paste) and affix te required warning labels on the containers (OSHA considers LCO2 to be hazardous material).
Thanks for the replies, folks. Much appreciated.
Given my company's infrastructure and building layout, it's starting to sound like a possibility would be to have a medium-size gaseous CO2 storage tank outside that the Praxair refil truck could get to easily (instead of having to hand-truck the 500 pound dewars up to our 2nd floor lab). Then use gas piping to get the gaseous CO2 up to the lab, and use cryogenic coolers/compressors to make LCO2 for storage in small holding tanks at each oven.
That would make the delivery process a lot easier, and would avoid one issue we have now with the 500 pound dewars venting from overpressure. The venting seems to be happening more lately (don't know why -- lower quality dewars maybe). Our use of LCO2 rises and falls, depending on what projects are being worked on, and where they are in their product development cycles.
I'll do some reading about the cryogenic coolers/compressors. Let me know if you have any more thougts or ideas. Thanks.
