Solar Voltaic Cells - converting sunlight to electricity over a given area
The discussion revolves around calculating the potential electricity generation from solar voltaic cells covering Lake Mead, given its average area and the intensity of sunlight received. The problem involves concepts from energy conversion and efficiency in the context of solar power.
  • Participants explore the relationship between area, sunlight intensity, and efficiency in calculating power output. Questions arise regarding unit conversion and the correct application of formulas.
Some participants have provided hints and clarifications regarding unit conversions and the method to calculate total power output. There is an ongoing exploration of how to correctly apply the given values and equations, with no explicit consensus reached on the final approach.
Participants are working under the constraints of a homework assignment, which may limit the information and methods they can use. There is also some confusion regarding the interpretation of the relationship between area and sunlight intensity.
jones2767
Solar Voltaic Cells -- converting sunlight to electricity over a given area
Lake Mead is formed by the Hoover Dam, and while it actually changes in area and volume, consider it has an average area of 100,000 acres. Assume that 250 W/m^2 of sunlight falls on Lake Mead, how much electricity could be produced if this lake area was covered by solar voltaic cells that convert sunlight directly to electricity with 15% efficiency?
I'm super confused. I have been working on this problem for about an hour, but I don't even know where to start.
The only equation I can think of to use would be:
F(in) = I x A
Where F is total incoming flux and I is the amount of sunlight??
What I have so far is that the Area would be 100,000 acres and the amount of sunlight is 250 W/m^2. I am assuming that I have to find the amount of Watts produced and take 15% of that. Could anyone give me a hint as to how to solve this?
1, How many m^2 are there in an acre (hint google calculator)
Once you know how many m^2 and you know that you receive 250W in each m^2 you know the total W
2, Yes you just take 0.15 of the power arriving
So, if there are 4.05 x 10^8 m^2 in 100,000 acres I would then take that number and divide by 250 W/m^2, which would give me roughly 1.61*10^6.
Then I just take the .15 of that?
Yes
A tip - carry the units through it helps to make sure you have things the right way around.
Power = w, area = m^2 and light arriving = w/m^2, so if you aren't sure what to divide by what
consider, to get power (W) you must have W/m^2 * m^2 = W
awesome! thank you so much! :)
Wait so I'm dividing the amount of sunlight by the area?
I thought I was dividing the area by the amount of sunlight?
Sorry I took a break in homework before returning to this problem
Carry the units along like mgb advised you to do. The units will help you to figure out what the numerator and denominator should be. Show your work if you want to ask another question.
by the way jones2767, mgb_phys errored slightly with the "yes" remark. So you need to get the units to cancel, leaving Watts, as berkeman says.
Sorry didn't chekc your figures,
4.05 x 10^8 m^2 * 250 W /m^2 * 0.15 = 15 GW
  • · Replies 21 ·
12K
