Solid formed by rotating equilateral triangle.
Mo
Determine the surface area and volume of a solid formed by rotating an equilateral triangle of side a about its base.
----------working out surface area--------
Integral of 2.pi.y dx with limits of a and 0.
I worked out; y = root3 . x
therefore surface area = root3.pi.a^2.
---------volume of revolution---------------
integral of pi.y^2. dx with limits of a and 0.
y = root3.x
therefore volume of solid formed = pi.a^3
I hope someone can check my answer to the first part (working out surface area) and then tell me where i went wrong with the volume of revolution.
The answer for the second part (volume of revolution) should be (pi.a^3)/4
Thanks.
Pretty close. The problem is with your equation y= sqrt(3) * x
I was working out the problem myself and was going to use symmetry, integrating from 0 to a/2, and multiply the answer by 2. This is when I noticed that your equation for y only works for values of x from 0 to a/2. i.e. the angle remains 60 degrees, and x keeps increasing. However, after a/2, the value of y starts decreasing.
Yes, that's true. So now i have worked out the value of surface area for half of the triangle and found that to be (pi.root3.a^2)/4
For the whole triangle, this value ahs to be multiplied by 2 surely?. Therefore final answer = (pi.root3.a^2)/2
The thing is, the answer i got given for this (first) part of the question was (pi.root3.a^2).
What else am i misssing in the solution?
Thanks for your help.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
