Solubility of Salicylic Acid: Acid vs Base Form
  • Thread starter Thread starter pisluca99
    Solubility
The solubility of salicylic acid is 2 g/L, and at a buffered solution with pH = pKa = 4.76, the total solubility increases, resulting in equal concentrations of salicylic acid and salicylate. The precipitation form depends on the pH: at pH < 1, salicylic acid precipitates; at pH > 5, salicylate precipitates. Between pH 1 and 5, both forms can coexist, and the specific precipitation can be determined using solubility product (Ksp) calculations for each form.
  • Understanding of pKa and its significance in acid-base chemistry
  • Familiarity with solubility product (Ksp) calculations
  • Knowledge of buffered solutions and their pH effects
  • Basic concepts of intrinsic solubility and its implications
  • Research the solubility product (Ksp) calculations for weakly soluble salts
  • Study the effects of pH on the solubility of weak acids and their conjugate bases
  • Explore the relationship between pKa and solubility in buffered solutions
  • Investigate the intrinsic solubility of other pharmaceutical compounds
Chemists, pharmacologists, and students studying acid-base equilibria and solubility in pharmaceutical formulations.
pisluca99
TL;DR
Brief clarification on the solubility of drugs based on pH.
The intrinsic solubility of salicylic acid is 2 g / L.
Suppose to put it in a buffered solution at pH = pKa = 4.76. In this situation, the total solubility increases and [acid] = [ coniugate base]. If this solubility is reached in solution, in what form does the drug precipitate? in the form of salicylic acid or salicylate?
Chemistry news on Phys.org
Not sure what you mean by that, please elaborate.
I don't think there is an universal answer to that. Depends on what is the solubility of the salicylate itself. This is not different from calculations done using Ksp for competing weakly soluble salts.
Sorry, I meant that pKa of salicylic acid Is about 3, so when pH = pKa, [salicylic acid]=[salicylate]. I got confused with pKa of acetic acid.
Can you make an example please?
Essentially, when pH Is < 1 (in this case), Stot=S0 of the acid (intrinsic solubility), so we can see precipitation of salicylic acid if its concentration reaches S0. Indeed, when pH Is > 5, Stot = S0 of the base (intrinsic solubility), so we can see precipitation of salicylate. But when 1<pH<5 we cannot neglect one of the two forms, so if we reach Stot= [acid] + [base] in solution, which form precipitates? I'm a bit confused.
Starting from "solubility product" you can write conditions for the precipitate to show as
Ksp1 = [SalH] (for the acid, and obviously [SalH] is a function of the total concentration and pH)
Ksp2 = [Sal-][Na+] (for the salt)
For a given pH and total concentrations of salicylate and Na+ you can always calculate whether one of the conditions is meet. If so - you know what starts to precipitate.
If both are met - something started to precipitate earlier, on your way to reach the conditions (and preparation of the solution with given parameters is actually impossible, unless we get into non-equilibrium conditions).
ok, so both species can potentially precipitate, once the pH is fixed. Thank you.
  • · Replies 20 ·
  • · Replies 48 ·
9K
