Undergrad Solution Expansion of ##A^{\mu}## when ##L \rightarrow \infty##
  • Thread starter Thread starter JD_PM
    Expansion
The discussion centers on the expansion of the vector potential ##A^{\mu}## in quantum field theory as the volume ##L \rightarrow \infty##. The Lagrangian density is given by ##\mathscr{L} = -\frac{1}{2} (\partial_{\mu} A_{\nu})(\partial^{\mu} A^{\nu})##, leading to the equations of motion ##\Box A^{\mu}=0##. The solutions are expressed as ##A^{\mu+}## and ##A^{\mu-}##, which generalize to integrals over momentum space when transitioning to infinite volume, resulting in equations ##(4.1)## and ##(4.2)##. The discussion also highlights the importance of polarization degrees of freedom and the implications of boundary conditions in quantum field theory.
  • Understanding of quantum field theory (QFT) concepts
  • Familiarity with Lagrangian mechanics
  • Knowledge of Fourier transforms in the context of field expansions
  • Basic grasp of polarization states in electromagnetic fields
  • Study the implications of periodic boundary conditions in quantum field theory
  • Explore the quantization of fields in the Coulomb gauge
  • Learn about the role of polarization states in vector fields
  • Investigate the mathematical transition from summation to integration in QFT
Physicists, particularly those specializing in quantum field theory, theoretical physicists working on gauge theories, and students seeking to understand the mathematical foundations of field expansions in infinite volumes.
JD_PM
TL;DR
I wanted to discuss the generalization of free-Maxwell's solution. More insight is very welcomed.
Please note that
I'll write ##A^{\mu} := A^{\mu}(x)## for simplicity.
I'll work in natural units.
The Lagrangian density ##\mathscr{L} = -\frac 1 2 (\partial_{\mu} A_{\nu})(\partial^{\mu} A^{\nu})## has equations of motion
$$\Box A^{\mu}=0 \tag{1}$$
We expand ##A^{\mu}## in a complete set of solutions of the harmonic equation ##(1)##
$$A^{\mu}=A^{\mu+}+A^{\mu-} \tag{2.1}$$
Where
$$A^{\mu+}=\sum_{r=0}^3 \sum_{\vec k}\Big(\frac{1}{2V \omega_{\vec k}} \Big)^{1/2} \epsilon_r^{\mu}(\vec k) a_r(\vec k)e^{-ik \cdot x} \tag{2.2}$$
$$A^{\mu-} = \sum_{r=0}^3 \sum_{\vec k}\Big(\frac{1}{2V \omega_{\vec k}} \Big)^{1/2} \epsilon_r^{\mu}(\vec k) a_r^{\dagger}(\vec k)e^{ik \cdot x} \tag{2.3}$$
And
$$V=L^3, \ \ \ \ \omega_{\vec k}:= |\vec k|=k^0$$
Alright. I started wondering why there was a volume term involved in the solution expansion. After reading a bit I understood why. It has to do with the concept of a field (which is defined at every spacetime point and describes mechanical systems with infinite degrees of freedom) and making the problem simpler.
We are dealing with the vector potential ##A(\vec x , t)## which, at a given instant of time ##t##, must take a value at every spatial point ##\vec x##.
To simplify the problem then, the mechanical system is enclosed in a cube of volume ##V=L^3## and some periodic boundary conditions are imposed
$$x \approx x+L, \ y \approx y+L, \ z \approx z+L, \tag{3}$$
I understand that by doing that, we go from having an arbitrary 3-vector ##\vec k \in \Bbb R^3## to ##\vec k \in 2\pi/L## (where the ##2\pi## factor is chosen so that the solution-expansion term ##\exp(\mp ik \cdot x)=\exp(\mp ik^0 \cdot x^0) \exp(\pm i \vec k \cdot \vec x)## is single-valued).
Thus I understand that ##(2.2)## and ##(2.3)## are solutions of the mechanical system enclosed in a 3D lattice.
Once here: what if we wanted to generalize ##(2.2)## and ##(2.3)## for an infinitely large volume ##V_{\infty}##? Well, then we should take ##L \rightarrow \infty## in our periodic boundary conditions ##(3)##. In such conditions the summation becomes an integral; i.e. (Mandl & Shaw page 12, footnote ##9##)
$$\frac{1}{V} \sum_{\vec k} \rightarrow \frac{1}{(2 \pi)^3} \int d \vec k \tag{*}$$
So I'd say that ##(2.2)## and ##(2.3)## generalize to
$$A^{\mu+}= \frac{1}{\sqrt{16 \pi^{3}}} \sum_{r=0}^3 \int d \vec k \Big(\frac{1}{\omega_{\vec k}} \Big)^{1/2} \epsilon_r^{\mu}(\vec k) \tilde a_r(\vec k)e^{-ik \cdot x} \tag{4.1}$$
$$A^{\mu-} = \frac{1}{\sqrt{16 \pi^{3}}} \sum_{r=0}^3 \int d \vec k \Big(\frac{1}{\omega_{\vec k}} \Big)^{1/2} \epsilon_r^{\mu}(\vec k) \tilde a_r^{\dagger}(\vec k)e^{ik \cdot x} \tag{4.2}$$
Comparing to ##(2.2), (2.3)## we notice that the ladder operators get rescaled
$$a_r (\vec k) \rightarrow \tilde a_r (\vec k) = \sqrt{\frac{V}{(2\pi)^3}} a_r(\vec k) \tag{5.1}$$
And
$$\tilde a_r^{\dagger} (\vec k) =\Big( \tilde a_r(\vec k) \Big)^{\dagger} \tag{5.2}$$
Do you agree with the generalization ##(4.1), (4.2)##?
Extra insight is very welcomed!
Thanks :biggrin:
I agree with your (4.1) and (4.2). In fact, that's pretty standard in QFT literature.
But there should be only 2 polarization degrees of freedom, at least when you use the simpler solution of the quantization problem starting from a completely fixed Coulomb gauge, i.e., ##\vec{\nabla} \cdot \vec{A}^{+}|\text{phys} \rangle=0##. In this gauge it automatically follows for the the free field that ##A^0=0## and you have only the two transverse polarization degrees of freedom. You can choose them as helicity eigenfunctions ##\pm 1## (corresponding to left- and right-circularly polarized plane waves).
Likes dextercioby
As the volume of your box goes infinity your ladder operators blow up. Infinity isn't a number, it's a place. You can't impose boundary conditions with a non-number. That's why people usually require the field to vanish at infinity.
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 0 ·
