Solution for Expressing Derivatives in Terms of u
  • Thread starter Thread starter gtfitzpatrick
    Derivatives Terms
34 replies · 4K views · last reply
gtfitzpatrick
w(r,[tex]\theta[/tex])= u(rcos [tex]\theta[/tex]),rsin([tex]\theta[/tex])) for some u(x,y)
express [tex] \frac{ \partial w}{\partial r}[/tex] and [tex]\frac{ \partial w}{ \partial \theta}[/tex] in terms of [tex]\frac{ \partial u}{ \partial x}[/tex] and [tex]\frac{ \partial u}{ \partial y}[/tex]
rewrite the following PDE and initial conditions in terms of w,r and [tex]\theta[/tex] and solve
y[tex]\frac{ \partial u}{ \partial x}[/tex] - x[tex]\frac{ \partial u}{ \partial y}[/tex] = 1 where u(x,0) = 0 for 0<x<[tex]\infty[/tex]
[tex]\frac{ \partial w}{ \partial r}[/tex] = [tex]\frac{ \partial u}{ \partial x}[/tex] . [tex]\frac{ \partial x}{ \partial r}[/tex] + [tex]\frac{ \partial u}{ \partial y}[/tex] . [tex]\frac{ \partial y}{ \partial r}[/tex]
and
[tex]\frac{ \partial w}{ \partial \theta}[/tex] = [tex]\frac{ \partial u}{ \partial x}[/tex] . [tex]\frac{ \partial x}{ \partial \theta}[/tex] + [tex]\frac{ \partial u}{ \partial y}[/tex] . [tex]\frac{ \partial y}{ \partial \theta}[/tex]
but I am not sure about part b...
and
You should be able to simplify these by using the relationship between [tex]x,y[/tex] and [tex]r,\theta[/tex].
Did you try to write this in terms of [tex]r,\theta[/tex]? You'll find that the form of the equation becomes very simple.
x= rcos [tex]\theta[/tex]
y = rsin [tex]\theta[/tex]
but how do i sub these in
As a first step you need to compute the derivatives [tex]\partial x/\partial r[/tex], etc. Then you need to determine the derivatives of u in terms of those of w and so on.
[tex] \frac{ \partial x}{ \partial r} [/tex] = 1
and [tex] \frac{ \partial y}{ \partial r} [/tex] = 1
so
[tex] \frac{ \partial w}{ \partial r} = \frac{ \partial u}{ \partial x} + \frac{ \partial u}{ \partial y}[/tex]
am i right in thinking this?
so
No. You just wrote that [tex]x=r \cos\theta[/tex], so how do you obtain [tex]\partial x/\partial r =1[/tex]?
OK, so you need to work out [tex]\partial w/\partial r[/tex] and [tex]\partial w/\partial \theta[/tex], then solve algebraically for [tex]\partial u/\partial x[/tex] and [tex]\partial u/\partial y[/tex].
[tex] <br /> \frac{ \partial w}{ \partial r} = \frac{ \partial u}{ \partial x}cos\theta + \frac{ \partial u}{ \partial y}sin\theta<br /> [/tex]
and [tex] <br /> \frac{ \partial w}{ \partial r} = \frac{ \partial u}{ \partial x}rsin\theta - \frac{ \partial u}{ \partial y}rcos\theta<br /> [/tex]
right?
[tex] <br /> <br /> \frac{ \partial w}{ \partial r} = \frac{1}{r}( \frac{ \partial u}{ \partial x}x + \frac{ \partial u}{ \partial y}y)<br /> <br /> [/tex]
and
[tex] <br /> <br /> \frac{ \partial w}{ \partial \theta} = \frac{ \partial u}{ \partial x}x - \frac{ \partial u}{ \partial y}y<br /> <br /> [/tex]
but I am not sure where to go from here...
and
[tex] <br /> \frac{ \partial w}{ \partial \mathbf{\theta}} = \frac{ \partial u}{ \partial x}rsin\theta - \frac{ \partial u}{ \partial y}rcos\theta<br /> [/tex]
right?
Now, like I said before, you want to solve these algebraically for [tex]\partial u/\partial x[/tex] and [tex]\partial u/\partial y[/tex]. You are then going to use those expressions to rewrite
[tex]y\frac{\partial u}{\partial x}-x\frac{\partial u}{\partial y}=1[/tex]
in terms of derivatives of [tex]w[/tex].
from [tex] \frac{ \partial w}{ \partial \mathbf{\theta}} = \frac{ \partial u}{ \partial x}rsin\theta - \frac{ \partial u}{ \partial y}rcos\theta[/tex]
and
[tex] y\frac{\partial u}{\partial x}-x\frac{\partial u}{\partial y}=1[/tex]
[tex] \frac{ \partial w}{ \partial \mathbf{\theta}} = 1[/tex]
this is killing me. its probably staring me in the face...
Well, what is the solution of that equation? Remember that this is a partial derivative, so the integration "constant" can depend on the other variable.
Next use the initial condition u(x,0) = 0 to fix the integration constant. What does the value y=0 correspond to in the polar coordinates?
[tex] \frac{ \partial w}{ \partial \mathbf{\theta}} = 1 [/tex]
[tex]w(r,\theta) = \theta + f(r)[/tex]?
im digging a big hole here i feel :(
That's correct. Now you have to figure out what y=0 means in polar coordinates and then apply the condition u(x,0)=0 to this solution.
thanks fzero for you patience!
ng code was used to generate this LaTeX image:
[tex] \frac{ \partial w}{ \partial \theta} = \frac{ \partial u}{ \partial x}y - \frac{ \partial u}{ \partial y}x[/tex]
[tex] \frac{ \partial w}{ \partial r} = \frac{1}{r}( \frac{ \partial u}{ \partial x}x + \frac{ \partial u}{ \partial y}y)[/tex]
so this the answer for part a?
and then i use
[tex] <br /> \frac{ \partial w}{ \partial \mathbf{\theta}} = 1 <br /> [/tex]
[tex] w(r,\theta) = \theta + f(r) [/tex]
and then as you say figure out what y=0 means in polar coordinates and then apply the condition u(x,0)=0 to this solution.
Yes, though I'm not sure whether your grader will care if you express it this way or in terms of the angle.
when y=o gives rcos[tex]\theta[/tex] = 0 can't br just that can it?
Well [tex]y=r\sin\theta[/tex], so you want to find the solutions of [tex]r\sin\theta=0[/tex].
how do i find the solution when there are 2 variables though? [tex]\theta[/tex] and r ? could there not be a any solution?
If the product
[tex]A(x) B(y)=0,[/tex]
then this is solved whenever either
[tex]A(x)=0[/tex]
or
[tex]B(y)=0.[/tex]
so either r=0
or [tex]\theta[/tex] = 0 or [tex]\pi[/tex] ?
gtfitzpatrick said:
so either r=0
Right. Now you were also told that [tex]0< x < \infty[/tex], so are all of those compatible with this condition?
[tex]\theta[/tex] must = 0 as cos[tex]\pi[/tex] = -1?
That's right. So what solution [tex]w(r,\theta)[/tex] satisfies the initial condition?
[tex]w(r,\theta)[/tex] = [tex]w(r,0)[/tex] ??
You're told that [tex]u(x,y=0)=0[/tex] for all allowed x. You found that [tex]y=0[/tex] corresponds to [tex]\theta =0[/tex]. So the initial condition is equivalent to [tex]w(r,\theta=0)=0[/tex]. Your general solution is
[tex]w(r,\theta) = \theta + f(r).[/tex]
What you want to do is use the initial condition to determine [tex]f(r)[/tex].
gtfitzpatrick said:
[tex] w(r,\theta) = f(r).[/tex]
What value does that take when [tex]\theta=0[/tex]? Is it consistent with the information you were given?
