Solution to an ODE using Power Series Method
4 replies · 3K views · last reply
eden2291
xy'-(x+2)y=-2x2-2x
I'm clueless as to how to solve this as I'm only experienced in using the power series method with homogenous ODE's. Even if I make this homogenous, I don't know what to do with the x-variables that are not attached to some y-variable.
Thanks you so much for any help.
I recommend dividing both sides of the equation by x, whereupon you will then get an equation in this form:
[tex]\frac{dy}{dx} + p(x) y = q(x)[/tex]
Which you can then solve using an integrating factor.
dextercioby said:
Do you know what the power series method means ? (The ODE can be integrated directly using an integrating factor http://en.wikipedia.org/wiki/Integrating_factor).
I do. And I know it can be solved using an integrating factor, but the directions for the assignment explicitly state that the solution must be obtained using the power series method.
