Solutions to a quantum harmonic oscillator - desperate for help
18 replies · 3K views
Bowenwww
I need to find the value σ for which:
ψ0(x) = (2πσ)-1/4 exp(-x2/4σ)
is a solution for the Schrödinger equation
I know the equation for the QHO is:
Eψ = (P2/2m)ψ + 1/2*mw2x2ψ
I've tried normalizing the wavefunction but I end up with a σ/σ term :(
Any help would be greatly appreciated :)
You aren't using the right form of the Schrödinger Equation. Try plugging it into the form with the derivatives:
[tex] E\Psi = -\frac{\hbar^{2}}{2m}\frac{\partial^{2}}{\partial x^{2}}\Psi + \frac{1}{2}m\omega^{2}x^{2}\Psi[/tex]
Solve the resulting equation
edit - wrote the wrong equation.
that is the equation I was using I just put P as the momentum operator :( I'm confused! Do I enter the wavefuntion into Schrödinger and then solve for what?
<3 xoxo
Are you given the general expression for [itex]E_n[/itex] ?? You are given the expression for [itex]\psi_n[/itex] for [itex]n = 0[/itex]. So take the necessary derivatives, plug in the expression for E_0 and recall that this solution must be valid for all x. Do you know a specific value for x that might make this much easier?
edit - the general expression for E isn't really necessary now that I think about it. You'll still be able to solve for [itex]\sigma[/itex] in terms of E
I can find σ in terms of E but the question says give the value for it that makes ψ0 (the one I originally posted) a solution to the Schrödinger
Then part II asks me to find the energy associated by putting the wavefunction ψ0 into Schrödinger like you said, so I'm guessing there must be an actual value or σ?
I'm really confuzzled! :(
All I'm given is the function ψ0 like I originally posted, nothing else.
<3 xoxo
Huh, I'm confused then as well, typically when a question asks you what value for a constant makes it a solution to an equation the thing to do is plug it into said equation. Could you possibly write out the entire problem? Or is it in a certain textbook? If so, what text and what's the problem number.
Part I
Find the value σ0 for which:
is a solution to the Schrödinger equation
Part II
What is the associated energy in part I? [hint: insert the given wave function into the Schrödinger equation]
That's it word for word.
Thank you so much for helping I really appreciate it! <3 xoxoxo
when you substitute ψ into schrodingers equation
Hψ=Eψ, you know E is a constant (independent of x)
but when you calculate Hψ you'll get terms proportional
to x^2. you need to pick σ so that those terms go away.
I put the wavefunction in and took the 2nd derivative and all that I canceled a load of common terms and ended up with
E = (-h(bar)2/2m)*(x2)/(4σ2) + 1/2*(mω2x2)
Is this right? I don't get how to pick a value so all the x's disappear?
<3 Cheers guys xoxox
qbert, that would mean [itex]\sigma[/itex] is a function of x^2. This is definitely not the case.
Bowenwww, You should end up with the following:
[tex]E = \frac{\hbar^{2}}{4m\sigma} - \frac{\hbar^{2}x^{2}}{8m\sigma} + \frac{1}{2}m\omega^{2}x^{2}[/tex]
more like:
[tex]E = \frac{1}{4}\frac{\hbar^2}{m \sigma}-\frac{1}{8}\frac{\hbar^2x^2}{m\sigma^2}+\frac{1}{2} m \omega^2 x^2[/tex]
Clever-Name, picking σ to make the x^2 terms 0 does not
mean that σ is a function of x. in fact, if you just do it
you'll see precisely what σ has to be!
So that's how I find out the energy levels, right? But I still don't know how to get the sigma?
I really appreciate this guys I just need pointing in the right direction ^ _ ^<3 xoxoxox
But there's still two unknowns E and sigma - sorry I know I'm being really stupid here; I know how to get to the form you've given I just don't know how to get from there to a value for sigma?
:( xoxox
pick σ to make the x^2 terms go away.
If [itex]C_1 = (a-2)x^2 +C_2[/itex] where [itex]a[/itex], [itex]C_1[/itex] and [itex]C_2[/itex] are all constants, then [itex]a[/itex] must equal 2 (otherwise [itex]C_1[/itex] would be a function of [itex]x[/itex], not a constant) and [itex]C_1[/itex] must equal [itex]C_2[/itex]
qbert you're right, my mistake, but your attitude is unnecessary. Bowen is obviously struggling to figure this out and your bitter responses aren't very helpful. I also made a typo in the equation you corrected. The appropriate thing to do is assume I made that typo instead of being so pompous in response.
Bowen, The last two terms (the ones with x^2) should cancel out based on what [itex]\sigma[/itex] is. In other words, their sum should be zero! Work that out and tell me what your answer for sigma is! i.e. solve this equation:
[tex] -\frac{\hbar^{2}x^{2}}{8m\sigma^{2}} + \frac{1}{2}m\omega^{2}x^{2} = 0[/tex]
wow. bitter and pompous and here i thought i was being helpful.
i'm sorry if i offended anyone, that wasn't my intention.
