aisha
- 584
- 0
I got x=1.4335735 off of my graphing calculator, but is it possible to solve without a graphing calculator?
The equation 3^(2x+1) = 70 can be solved using logarithms, specifically by applying the natural logarithm. The solution is derived as follows: (2x + 1)ln3 = ln70, leading to the calculation x = (ln70/ln3 - 1)/2, which results in approximately 1.4335735. While some participants suggested alternative methods, such as using inequalities, the consensus confirms that logarithms are essential for accurately solving this equation.
PREREQUISITESStudents learning algebra, educators teaching logarithmic functions, and anyone seeking to understand the application of logarithms in solving exponential equations.
Jameson said:using logs.
(2x+1)ln3 = ln70
Jameson said:i'm pretty sure that's the only way. logs are just another way of expressing radicals. But I won't go into detail.
If you solve that equation, you get 2x + 1 = ln70 / ln 3
so the answer is actually 2.43. that's what i get at least
Gecko said:i don't get how you got and used the inequality 70<81. couldn't you use the logarithim rule that states logx y= log a y/ log a x so then you would get 2x+1 = log 70/ log 3 which should give you the same answer as what jameson got, if he is correct.
edit: jameson was wrong, i did the calculations and got 1.433573512... which is what the person who asked the question got when he/she put it into a graphing calculator.
