Solve a nonlinear matrix equation
12 replies · 3K views
rehan_eme
TL;DR
Hi all,
I want to know if a second solution exists for the following math equation:
Ce^{At} ρ_p+(CA)^{−1} (e^{At}−I)B=0
Where C, ρ_p, A and B are constant matrices, 't' is scalar variable. I know that atleast one solution i.e. 〖t=θ〗_1 exists, but I want a method to determine if there is another θ_0<θ_1 that is also a (second) solution. Any anlaytical way of determining that is what I am looking for.
Add my vote to the hope that LaTex might add some neaded clarity. What does a scalar to a power of a matrix even mean?
Mayhem said:
Doesn't this show up in QM quite often? I remember seeing something to the effect of ##e^{\mathbf{X}}## before.
The exponentiation comes into play whenever we want to solve a differential equation when we turn something linear into something curved, the transition from a Lie algebra to a Lie group. However, the OP didn't provide any such context, no differential equation, no vector field. It is not even clear whether ##e^{At}## converges. It looks like a flow, but it would have been nice to know for sure.
I have not seen it in QM, or for that matter, ever. Raising a scalar to the identity matrix returns what? (Apparently, a disgonal matrix with the scalar on the diagonal,,,guess it has to be something)
Here is what I think it should have been:
rehan_eme said:
TL;DR Summary: Solve a nonlinear matrix equation
Hi all,
##Ce^{At} ρ_p + (CA)^{−1} (e^{At}−I) B=0## or ##C\exp(At) ρ_p + (CA)^{−1} (\exp(At) −I ) B=0##
Where ##C, ρ_p, A,## and ##B## are constant matrices, ##t## is a scalar variable. I know that at least one solution i.e. ##t=\theta_1## exists, but I want a method to determine if there is another ##\theta_0<\theta_1## that is also a (second) solution. Any analytical way of determining that is what I am looking for.
E.g. it could be that ##A\in \mathfrak{su}(2)## and ##e^{At}## is a flow in ##\operatorname{SU}(2).##
This is something that appears in all but the most elementary linear algebra textbooks. As a Maclaurin expansion ##e^A = I + A + \frac {A^2}{2!} + \frac {A^3}{3!} + \dots + \frac {A^n}{n!} + \dots##.
##e^I = I + I + \frac {I^2}{2!} + \frac {I^3}{3!} + \dots + \frac {I^n}{n!} + \dots##
##= I(2 + 1/2 + 1/6 + 1/24 + \dots) = eI##
That's surprising to me. Maybe I'm showing my age here, but back in the day, quantum mechanics textbooks often exponentiated the time-independent, Hermetian Hamiltonian ##H## (a differential operator or a matrix, depending on the representation) of a quantum system to define the unitary operator ##T## of time evolution (e.g., see the page from Merzbacher below). Maybe the QM texts you've studied no longer use that approach?
