Solve bernoulli differential equation with extra constant
7 replies · 4K views · last reply
Berrius
Find a solution for:
[tex]u'(t)=c*u(t)^2-c*(a+b)*u(t)+c*a*b[/tex]
I've found the solution for the homogeneous equation:
[tex]u_0(t)=(\frac{1}{a+b}+d*e^{c(a+b)t)})^{-1}[/tex]
Where c is a random constant.
Now I've tried the solution [tex]u(t)=x(t)*u_0(t)[/tex], when I fill this in it gets a mess and i can't figure out what x(t) should be.
Can someone help me?
This isn't a linear equation, so I'm not sure what you consider the "homogeneous" equation. If you write it as$$
u'+ c(a+b)u =cu^2+cab$$at least the left side of the equation is linear. That means if you can find a solution ##u_1## of ##u'+ c(a+b)u =cu^2## and a solution ##u_2## of ##u'+ c(a+b)u =cab## then ##u_1+u_2## should be a solution of your original DE.
With homogeneous I just ment the differential equation without the constant part.
But your approach won't work because [tex]u'(t)=u_1'(t)+u_2'(t)=-c(a+b)u_1(t)+cu_1^2(t)-c(a+b)u_2(t)+cab=-c(a+b)u(t)+cu_1^2(t)+cab[/tex]
Or am I seeing it wrong?
I would forget Bernoulli's equation and just try separation of variables. The right side factors. Just use partial fractions to integrate it.
Right. You can't combine them that way. Just separate.
You are seeing it wrong. If you let$$
L(u) = u' + c(a+b)u$$be the left side linear part then ##L## is a linear operator, which means ##L(u_1+u_2) = L(u_1)+L(u_2)##. So if ##L(u_1) = cu_1^2## and ##L(u_2)=abc##, what do you get for ##L(u_1+u_2)## ?
But you want to get ##L(u_1+u_2) = c(u_1+u_2)^2+abc##. You don't get that.
No wonder I was feeling a little uncertainty about my argument. :blushing: And it seemed so neat at the time...
