Solve Chandelier Tension Problem: Get Help from Nate
  • Thread starter Thread starter nateshoe
    Tension
The discussion centers on solving the chandelier tension problem involving two cables with tensions T1 and T2, attached at angles theta1 and theta2, respectively. The key equations derived from the equilibrium of forces are T1cos(theta1) = T2cos(theta2) for the x-direction and T1sin(theta1) + T2sin(theta2) - mg = 0 for the y-direction. The user Nate initially struggled with isolating T1 without knowing T2 but received guidance on correctly setting up the equations. Ultimately, Nate successfully solved the problem after addressing algebraic challenges.
  • Understanding of static equilibrium in physics
  • Knowledge of trigonometric functions and their applications
  • Ability to manipulate algebraic equations
  • Familiarity with free body diagrams
  • Study static equilibrium problems in physics
  • Learn about free body diagram techniques
  • Practice solving systems of equations involving trigonometric functions
  • Explore applications of tension in real-world scenarios
Physics students, engineering students, and anyone interested in understanding the principles of tension and equilibrium in mechanical systems.
nateshoe
A chandelier with mass m is attached to the ceiling of a large concert hall by two cables. Because the ceiling is covered with intricate architectural decorations (not indicated in the figure, which uses a humbler depiction), the workers who hung the chandelier couldn't attach the cables to the ceiling directly above the chandelier. Instead, they attached the cables to the ceiling near the walls. Cable 1 has tension T_1 and makes an angle of theta_1 with the ceiling. Cable 2 has tension T_2 and makes an angle of theta_2 with the ceiling.
3. The Attempt at a Solution [/b]
I can get this far:
We know the sum of the forces in the x and y direction equals zero so;
for the x:
T1cos(theta1)=T2cos(theta2)
for the y;
T1sin(theta1)=T2sin(theta2)-mg
I need to fiind the magnitude of T1 without using T2
I'm stuck and could use a hand.
Thanks,
Nate
It's better to write your equations as "the sum of forces = 0", to avoid mistakes like the one in your second equation. When you draw the free body diagram of a stationary object, the forces all must sum to zero.
for x: T_1 cos(\Theta_1) - T_2 cos(\Theta_2) = 0 (which is in the - x direction? T1 or T2?)
for y: T_1 sin(\Theta_1) + T_2 sin(\Theta_2) - mg = 0
You now have two equations in two unknowns, so you can solve for the two tensions. Please show your work as you solve them.
thanks I got it solved I was just striggling with the algebra
27K
10K
14K
10K
