Solve Cos(x)=-2: Step-by-Step Guide
  • Thread starter Thread starter GreenPrint
46 replies · 20K views
then I just plug in what I got for my answers into the formula? where my answer is the z? Wow well thanks for the help hmmm that's interesting let me see what I get...
No, your answer is the [itex]w[/itex] and [itex]z = -2[/itex].
what are you using for that slanted p value? let me look again hold up
GreenPrint said:
my only question is why didn't you use +/- and just used +
The complex square root is a double - valued function:
[tex] z = w^{2}, \; z = \rho \, e^{i \, \theta}, \; w = R e^{i \Theta}[/tex]
[tex] \rho = R^{2} \Rightarrow R = \sqrt{\rho}[/tex]
[tex] \theta + 2 \, n \, \pi = 2 \, \Theta \Rightarrow \Theta = \frac{\theta}{2} + n \, \pi, \; n \in \mathbb{Z}[/tex]
But, [itex]\Theta[/itex] is restricted to a period of [itex]2 \, \pi[/itex] so:
[tex] \sqrt{z} = \left\{\begin{array}{l}<br /> \sqrt{\rho} \, e^{i \, \frac{\theta}{2}} \\<br /> <br /> \sqrt{\rho} \, e^{i \, (\frac{\theta}{2} + \pi)}<br /> \end{array}\right.[/tex]
ok well thanks I'll post post back if i get stuck again i need to do some more stuyding of this stuff :)
But, your initial hunch was correct. The equation in the topic of the thread does have (infinitely many) solution(s) in the set of complex numbers [itex]\mathbb{C}[/itex].
So my final answers should be
2 pi n - i(-2 + sqrt(3))
and
2 pi n -i(-2 - sqrt(3))
where n is the set of integers?
and
Where is the [itex]\ln[/itex] function and what is the absolute value and argument of:
[tex] -2 + \sqrt{3}[/tex]
and
[tex] -2 - \sqrt{3}[/tex]
sorry I forgot the ln
so is this correct
2pi n - i ln(2 + sqrt(3))
and i take the absolute value of the argument in the natural log leaving me with only positives? where n is the set of integers
argument of a complex number [itex]z = \rho \, e^{i \, \varphi}[/itex] is the variable [itex]0 \le \varphi < 2 \pi[/itex]. What is it for the two inputs of the complex logarithm?
2 and sqrt(3)... right?
no. you need to look up trigonometric form of a complex number.
ok and what exactly am I looking for
z = |z|[cos (t) + i sin (t) ]
right it's the cosine and sine of the angle?
If cos(z)=-2, then just use:
[tex] \cos z=\cos (x+yi)=\cos x\cos (yi)-sin x\sin (yi)=\cos x\cosh y-i\sin x\sinh y=-2[/tex]
Compare real and imaginary parts to obtain:
[tex] \cos x\cosh y=-2\quad\sin x\sinh y=0[/tex]
Clearly x must be a multiple of pi and that you can work you the solution for what y has to be.
