Solve derivative of least squares matrix equation
The discussion focuses on deriving the optimal transform matrix T for a MIMO communication system, where the received signal is expressed as r = Hs + n. The least squares solution is sought to minimize the error D = ||s - s_hat||^2, leading to the equation dD/dT = 0. A critical observation is that the matrix T cancels out in the expression for D, resulting in D = 0, which implies a need for reevaluation of the approach due to the noise affecting s_hat. Participants also seek recommendations for literature on matrix algebra relevant to this topic.
  • MIMO communication systems
  • Matrix algebra and linear transformations
  • Least squares optimization techniques
  • Understanding of noise in signal processing
  • Study the derivation of the least squares solution in MIMO systems
  • Learn about the impact of noise on signal estimation
  • Explore matrix calculus for optimization problems
  • Read "Matrix Algebra and Applications" for in-depth understanding
Engineers and researchers working on MIMO communication systems, signal processing specialists, and students studying advanced matrix algebra and optimization techniques.
beyondlight
I am designing a MIMO communication system, with input signal s, channel H and transform matrix T. The received signal is corrupted by noise.
[/B]
The received signal is r = Hs+n
And then it is transformed (compressed) by:
y = Tr
And then its estimate s_hat is computed:
s_hat = inv(TH)*y = inv(H)inv(T)THs + inv(H)inv(T)Tn
Set C = inv(H)inv(T)Tn
I want to find an optimum T based on the least squares solution:
D = norm(s-s_hat)^2
dD/dT = 0
[/B]
D= (s-s_{hat})^{H}(s-s_{hat})=0
D = (s-H^{-1}T^{-1}{THs})^{H}(s-H^{-1}T^{-1}THs)
D = ||s|| -s^{H}H^{-1}T^{-1}{THs}-s^{H}C-s^{H}H^{H}T^{H}(T^{-1})^{H}(H^{-1})^{H}s+(s^{H}H^{H}T^{H}(T^{-1})^{H}(H^{-1})^{H}s)(H^{-1}T^{-1}{THs})-sH^{H}T^{H}(T^{-1})^{H}(H^{-1})^{H}C-C^{H}s-C^{H}H^{-1}T^{-1}{THs}+C^{H}CHow do I find the derivative dD/dT? Suppose that I do find it, how then do I proceed to obtain T alone on one side of the equation?
I would also like to get some ideas on which book covers this kind of matrix algebra.
[/B]
y = Tr
D = norm(s-s_hat)^2
dD/dT = 0
[/B]
The matrix ##T## disappears from your expression for ##D## as you have written it:
##H^{-1} T^{-1} T H = H^{-1} H = I## (the unit matrix), because ##T^{-1}T = I## and ##H^{-1}H = I##. So, what you have written is, basically, ##D = (s-s)^H (s-s)##, which is just 0 for all ##H, T##.
But since s_hat is corrupted by noise then this will not be exactly true?
I am just going by what you wrote. Perhaps what you wrote is not appropriate.
  • · Replies 24 ·
