Solve Derivative of y = x2sinx
12 replies · 2K views
goonking
y = x 2sinx
Ok, so If I see an x in an exponent, I would want to use ln to 'bring it out', right?
ln y = ln (x 2sinx) = ln x + ln 2sinx = ln x + sinx ln2
now I take the derivative :
y'/y = 1/x + cosx ln2
multiply both sides by y
y' = [1/x + cosx ln2] (x 2sinx)
is everything correct?
Yes it looks correct. You could have also done a product rule + chain rule expansion. That way you could avoid the implicit form,
ok, cool. Thanks!
goonking said:
y = x 2sinx
Is x multiplied by 2sin x, or is it something else?
yes , multiplied.
could you show your work for that?
goonking said:
y = x 2sinx
It is correct, but should be re-written as ##y' = 2^{\sin(x)} + \ln(2)\, \cos(x)\, x \, 2^{\sin(x)}##. The way YOU wrote it would not allow you to easily get ##y'(0)## because it would involve the "illegal" fraction ##\frac{0}{0}##. The way I wrote it presents no problems at ##x = 0##.
y = x 2sinx
Product rule says [itex]y'(x) = f'(x)g(x) + f(x)g'(x)[/itex]. Choose f(x) = x, and g(x) = 2sinx. (although order doesn't really matter)
Now, all you have to do is compute the derivative of f, the derivative of g, and then plug. The derivative of g also involves the chain rule. Try figuring it out for yourself, it should be more rewarding. You already know the answer so you'll know if you've got it. Good luck :D
Wait, how did you get 2sin(x)+ln(2)cos(x) when I got 1/x + ln2 cosx?
Brian T said:
y = x 2sinx
but to get the derivative of 2sinx, I need to use ln right? is there any other way?
He just distributed the term you had outside your parenthesis.
The derivative of some scalar a, raised to the x, is:
[itex]\frac{d}{dx}[a^x] = (a^x)ln(a)[/itex] ... as a side note unrelated to this problem, think about when the scalar a = e.
So, applying the chain rule the derivative of scalar a, raised to some f(x), is:
[itex]\frac{d}{dx}[a^{f(x)}] = (a^{f(x)})ln(a)f'(x)[/itex]
scalar a = constant right?
also, this whole time, i thought [itex]\frac{d}{dx}[a^x] = (x)ln(a)[/itex] , i thought you only move the exponent out, but you moved both the base AND exponent.
edit: Oh, I think i understand now. if you have a constant to the x power, like 52x then it becomes 52x ln5 ⋅2
but what if it is a variable to a power of another variable, for example y5x
is it going to be y5x ln y ⋅5 ?
Here's how it works. As long as x > 0, you can write x as ##e^{ln(x)}##.
So ##5^{2x} = (e^{ln(5)})^{2x}##
Using one of the rules of exponents, the above is equal to ##e^{2x*ln(5)}##. This form is much easier to differentiate.
