Solve Distance for Box A Sliding Down Ramp
3 replies · 7K views · last reply
VinnyCee
The 30 lb box A is released from rest and slides down along the smooth ramp and onto the surface. Determine the distance s from the end of the surface to where the box stops. The coefficient of kinetic friction between the cart and the box is [itex]\mu_k\,=\,0.6[/itex].
http://img224.imageshack.us/img224/8509/problem14343jq.jpg
Here is what I have so far:
[tex]-W\,\Delta\,y\,=\,(-30\,lb)\,(-4\,ft)\,=\,120\,ft\,lb[/tex]
[tex]\sum\,F_y\,=\,N\,-\,W\,=\,0\,\Rightarrow\,N\,=\,W\,=\,30\,lb[/tex]
[tex]\sum\,F_x\,=\,-f_k\,=\,m\,a_x\,\Rightarrow\,-\mu_k\,N\,=\,m\,a_x[/tex]
[tex](-0.6)\,(30\,lb)\,=\,(0.932)\,a_x[/tex]
[tex]a_x\,=\,\frac{-18.6}{0.932}\,=\,-19.3\,\frac{ft}{s^2}[/tex]
Now what?
I know I need to find [itex]v_f[/itex] and the bottom of the hill and I am probably supposed to use a work-energy equation?
[tex]\sum\,T_1\,+\,\sum\,U_{1\,-\,2}\,=\,\sum\,T_2[/tex]
Please help, thanks.
VinnyCee said:
know I need to find vf and the bottom of the hill and I am probably supposed to use a work-energy equation?
Yes, as the ramp is frictionless the kinetic energy gained by the block will equal the work done by gravity; 1/2mv2 = mgh. A good point to note for future reference is that the velocity of the object is independent of the mass.
Using that, I get this:
[tex]V_f^2\,=\,2\,g\,h\,=\,2\,(32.2)\,(4)\,=\,257.6[/tex]
[tex]V_f\,=\,\sqrt{257.6}\,=\,16.05\,\frac{ft}{s}[/tex]
[tex]v\,=\,v_0\,+\,a\,t[/tex]
[tex]0\,=\,16.05\,+(-19.3)\,t[/tex]
[tex]t\,=\,0.832\,s[/tex]
[tex]s\,=\,s_0\,+\,v_0\,t\,+\,\frac{1}{2}\,a\,t^2[/tex]
[tex]s\,=\,0\,+\,(16.05)\,(0.832)\,+\,\frac{1}{2}\,a\,t^2[/tex]
[tex]s\,=\,6.67\,ft[/tex]
The real answer is 3.33 ft though! What did I do wrong?
Your going to kick yourself for this one. You have calculated the distance travelled, not the distance from the end of the platform. HINT: What does 10 - 6.67 equal? :wink:
