Solve dy/dx + 2y = xe^x using integrating factor
tunabeast
[tex]\ \frac{dy}{dx} + 2y = xe^x[/tex]
I'v only ever solved differential equations where values can be separated easily, i understand i may have to use something called the integrating factor but this does not seem to fit the formula layout of
The equation you presented:
[tex]\frac{dy}{dx}+p(x)\cdot y=q(x)[/tex]
is a linear differential equation of the first order. This is the next type you learn after the ones you can separate immediately. It has a general solution. What is your knowledge on the ways for solving these? You should have some idea about this, can you show an attempt of solving it?
... does not seem to fit the formula layout of
Why not? What doesn't match?
