- 3,446
- 3,685
zoobyshoe said:the puzzleland toy store charges $6 for a doll, $7.50 for a train, $4.50 for a top, and $12 for a paint set.
What would you pay there for a bicycle?
$10.50
The store charges by the letter.
Correct on both counts!collinsmark said:[Edit: More detailed spoiler:]$10.50
Office_Shredder said:This is a cheap answer to the water transfer problem:
It says that we have to transfer SOME water from one glass to the other, so that both have about the same amount of water. So step 1 is to pour water from the jug into the empty glass until the glasses have about the same amount of water. At this point, if I transfer a very small amount of water from one glass to the other, then I will have transferred some water from one glass to the other, so that both have about the same amount of water (indeed, if I transferred more I would make the one glass have too much!). So I dip the paper towel into the one glass, and squeeze the water out into the other glass, completing the task
Enigman said:Wait on me...yet again.
(more hypothetical money this time.)
I go to a restaurant and ask the waiter (you) to bring me two glasses, a jug of water, matchsticks, a table spoon, fork, paper towels and a fruit (just for the sake of tradition).
You bring the said things and set them on the table. I pour water from the jug into a glass and challenge you to transfer some water from the glass to the empty glass so that they both have approximately equal amounts of water. And of course do this without touching the glasses (or breaking them), you may use anything on the table and nothing else. Glasses are set at a close distance and may not be moved from their original places.
Extra tips- $200*
*T&C applied- money in concern is perfectly imaginary.[/size]
collinsmark said:Let's assume that the two glasses are close together. If not use the fruit to attract Gad and then light a match which is laced through the prongs of the fork which is placed under the table. This startles Gad causing her to bump the table such that the glasses end up being closer together. (Or you could just kindly ask Gad to move one of the glasses next to the other.)
I am regretting ordering the spoon now...Office_Shredder said:Or how about
Use the spoon to scoop out a cavity in the fruit. Stick the fork in the fruit, and dip it into the full glass. Then pour the water filling the cavity into the empty glass. Rinse and repeat. Light your 200 dollar tip on fire with the matchstick and use it to smoke a cigar.
Or even better
Use the spoon to scoop water out of one glass and dump it in the other one. Rinse and repeat
Enigman said:Bottle is fine and filled with water. What's your favourite fruit Gad?
Gad said:Ok, cause it's locked inside a broken vending machine.
Gad said:You must be thirsty to hold it in your hand. :p
Enigman said:I wouldn't drink it...You must be thirsty to hold it in your hand. :p
No.consciousness said:First guess is-
The bottle is actually made out of ice. By the time you pour out some water it can be argued that some ice melted and there is some water inside the ice. Holding it would be a pain too.
consciousness said:Another answer-
The bet took place at one of poles. The water will simply freeze when you try to pour it out. Taking the ice out will be a real challenge.
Office_Shredder said:My guess is something like
you are going to squeeze the bottle, put the cap on, then pop the bottle back into shape creating a vacuum inside and preventing you from ever uncapping it. Is this actually possible, I do not know
So far so good.Office_Shredder said:The bottle is a hard plastic (can't be deformed) and you just removed it from a very cold freezer.
Water expands on freezing so the pressure should be greater.The pressure in the bottle was 1 atmosphere going in, so with the temperature decrease it is now much less than one atmosphere. You shouldn't be able to open it until the bottle warms back up again (which if it's a thermos for example will be a very long time)
