Solve for I and U using Thevenin's Theorem
28 replies · 4K views
Daeol
Hello guys!
I am getting really desperate here and I'd be very glad for any help.
I have the following circuit with 5 resistors :(excuse the drawings, I am in a hurry, I hope they are sufficient)http://s11.postimg.org/8mmd2pa2b/original.png
And I am supposed to solve for IR3 and UR3.
So my guess was to first transform it into a linear circuit so I put R1 R2 and R4 and R5 together:
R12 = R1*R2/R1 + R2
R45 = R4*R5/R4 + R5
So the circuit would be now simplified like this and I could apply the theorem:
http://s7.postimg.org/57r3m1b1n/step2.png
And now I removed R3, and solved for Rt = R12*R45/R12 + R45
Then I figured out the current Ix*R12 + Ix*R45 = U
Ix = U/R12 + R45
And then the Ut = U - IxR12
When I put it all together like this to figure out IR3:
IR3 = Ut/Rt + R3
I am not getting the right value so I must be doing something wrong.
I solved the circuit using the Star Delta transformation and I got all the right values.
I am not posting any numbers because I want to solve this myself, I just need someone to point me in the right direction.
I am a beginner and I would be extremely glad for any help I can get.
Thank you and have a great day!
Daeol said:
R12 = R1*R2/R1 + R2
Well, that leaves 2R !
You should make two Thevenin equivalents:
A) For R1, R4
B) For R2, R5
Now setup:
A--------R3---------B
Calculate current through/voltage across R3.
Hello there and thank you very much for your reply!
I am not quite sure what you mean by "that leaves 2R".
Was combining the parallel resistors not a right step?
And I am not sure which equivalents do you mean right now. Could you please elaborate?
Should I combine R1 and R4?
Thank you again!
Perhaps this will hep you move forward. With R3 removed from the circuit it should be clear that you have two potential dividers providing potentials at the open terminals where R3 sat. Each potential divider is comprised of a pair of resistors and a driving voltage U. Redraw the circuit so that the two potential dividers are shown separately:
You can provide each with its own voltage source U without changing how the circuit operates, since both potential dividers are driven by a potential U to begin with and they don't interact in any way with R3 out of the picture.
Now you should be able to reduce each of the potential dividers to their Thevenin equivalents and then proceed to further simplification. In fact, you should be able to work out the overall Thevenin equivalent pretty much by inspection.
Hello there, I am afraid I am not really getting it : (
Could you please specify what was wrong with my method of simplifying the circuit?
I was thinking, if I remove R3, I should then combine R1 and R2 and R4 and R5 like I have written above in order to get a linear circuit, I have no idea what you have done there where you put R4 and R1 and R5 and R2 together like that.
Also, do I need to use another voltage source? Do I need it for figuring out Ut? How will I get its value? I have the value of the original source only.
Thanks a lot!
Thanks a lot!
You will find gneill's suggestion explained in more detail here: http://www.hallikainen.com/rw/theory/theory6.html
Sorry, my fault. It should have been:
R12 = R1*R2/R1 + R2 = 2*R2.
Yes, as qneill has shown ( same with R2, R5 ).
R1 and R2 will not become in parallel even if you remove R3. Both ends of R1 will not be connected to R2. Only if you short circuit R3, R1 and R2 are connected in parallel, but then you change the all over circuit.
Okay guys, I think I might be on the right track!
So, to figure out Rt, instead of treating R1,R2 and R4,R5 like parallel, I do this:
R14 = R1 + R4
R25 = R2 + R5
And with R3 removed, R14*R25/R14 + R25 should give me Rt.
Then to figure out Ut, I calculate the current Ix = U/R14 + R25 and then Ut = U - IxR14 while still treating the resistors as linear?
Is that approach correct? I am not sure about the Ut because I am not sure whether the current should be splitting between UR14 and UR25 with the voltage source now present or not.
I am getting an IR3 that matches the IR3 I calculated via the Start Delta method for 2 decimal figures so I am not sure whether I am still doing something wrong or not.
Thanks for all your help guys!
Nope. Consider the diagram I gave in post #4. You are looking for the resistance between terminals a and b in that diagram, with the sources suppressed of course. Can you sketch the diagram with the sources suppressed?
Like this?
http://s2.postimg.org/gohtw4evd/surpressed.png
I do appreciate your picture you posted earlier but it rather confused me, especially since you added a second source which was not in the original circuit.
I am trying to follow the instructions the professor showed us in the class but it was just one, very simple example with not much explanation how exactly it works, thus I struggle with applying it to this more complex circuit.
What did I do wrong when calculating the resistance?
A Thevenin equivalent looks like this (dashed box).
It's an emf ( Voc ) in series with the inner resistance, Rth ( like a battery ).
So you must calculate Voc and Rth as for A and B ( separately ). Now attach R3 in between:
A---------R3---------B.
Daeol said:
Like this?
Suppressing the sources in the diagram of post #4 means to replace the sources with a short circuit (a simple wire, in other words). If you replace the left source U with a wire, what is the resistance from point A to ground? Do the same for the resistance from point B to ground; what is that resistance?
Okay guys, I think I better show you the example I have been given, so you know what knowledge I am supposed to be using while solving this problem.
http://postimg.org/image/fo6brj1kx/
http://postimg.org/image/x3wh42fk5/
http://postimg.org/image/4pdc7o4vb/
I' d say this one example is not sufficient in the least but that's what I have been given to work with.
So I am not quite sure what you mean by saying I need to figure the resistance of A while in this simple example, I could just figure both at once which is what I thought I should do in the more complex one as well once I combine together R1,R4 and R2,R5.
Daeol said:
Yup.
Splitting a node by duplicating the source that drives it is okay so long as it doesn't change any of the potentials in the circuit. I did it to try to make clear that there are essentially two separate voltage dividers:
The potentials driving the voltage dividers are the same after the source is duplicated. So you have one voltage divider providing the potential at terminal a, and another providing the potential at terminal b. The figure in post #4 was just a rearrangement of the the dividers on the page to highlight their independence and make it more obvious how to get at the Thevenin equivalent. And in fact you've successfully determined what the circuit would look like from the point of view of the open terminals with the sources suppressed.
Now, how might you determine the open potential across the terminals a-b?[/quote][/quote]
Hey there qneill, please check out what I have posted just above your post.
I really do not get the "You must calculate the Voc and Rth as for A and B ( separately )" part since I was presented with an equation that did both at once.
Did I at least get any of the steps right?
In the example you presented above, one of the target terminals was also the reference node, so you only had to determine the potential at one location (with respect to that reference node). The method and results were fine.
In the present case you have two terminals, neither of which is the reference node. Yet you want to find the potential difference between them. The simplest way to go about that is to determine their potentials separately with respect to a common reference, then take the difference.
You can do this in several different ways. One is to recognize that the terminals in question are each part separate voltage dividers and use the voltage divider formula. Another is to render them both into their own Thevenin equivalents, then combine those into a single Thevenin equivalent. That would get you to your overall result of both Vth and Rth in one set of steps, although you've already determined Rth so it might be extra work for little gain (except perhaps practice).
I'd suggest going the voltage divider route at this point. Work with the bottom figure in post #14. Find the potentials at a and b.
I am afraid I have no idea what a reference node means or what it is supposed to do : /
My intuition tells me that its the "ground" towards which the arrow was pointing in the pictures I posted and since the b terminal was there, it was easier to determine the potential.
And what I understood from what you wrote is that I need to figure out the current for each circuit and then use it to calculate the Ua and Ub ?
But maybe I got it all wrong.
The drawings above were all I was given with almost zero explanation so if you could please explain which one was it and why, and why here it is not the case, I would be extremely grateful.
The class appears to be very poorly organized and as much as I would love the professor introduced us to more complex scenarios and explained this stuff thoroughly, I doubt this will be the case.
And I would really prefer a human being to tell me why something is the way it is rather than searching on google.
Thank you very much for your time and patience! As I have said, I am a beginner and this is all very new stuff for me and can be quite hard to wrap my head around at times.
Yes, the reference node is one that you choose for convenience and is usually designated by the little triangle symbol (there are other symbols that are used occasionally, but the triangle is quite prevalent). Think of it as the spot in the circuit where you might attach the negative lead of a voltmeter and then use the other lead to measure various potentials elsewhere in the circuit: it is thus the reference point to which you refer other potentials. You are free to choose any node as a reference node, but most often a particular choice will be more convenient than others. It's largely a matter of experience to develop the insight and intuition to choose a node that will make your analysis easier.
No, that's a reasonable way to proceed. Find the current then use it to determine the potential drops across the resistors in order to establish the potential at the node in question (do a "KVL walk" from the reference node to the node in question, summing the potential changes along the way). The voltage (or potential) divider rule that I've mentioned several times really just combines these two steps into one operation. The situation comes up so often in circuit analysis that the resulting reduced formula has been named. There's an analogous rule for current division.
In the example you gave the reference node of choice happened to coincide with the lower connection point for the load for convenience. The reference node is always assumed to be the zero potential reference point in a circuit (unless otherwise specifically stated), so that (conveniently) gives you potential at that node without having to do any work to find it. That left only the potential at the top connection to find (where the top of R3 connects when it's in the circuit). A KVL walk from the reference node to that terminal might pass through V2 and R2 (or the other way around the loop, through V1 and R1).
Sorry to hear about your class "style". Fortunately we are here to help where we can :smile:
Okay I am just about to give up. Today's class was even more disappointing and we didn' t do any of these circuits so I would like to ask you if you could provide me with a step by step solution (with pictures that have arrows symbolizing the Ut and Rt I am looking for if possible, I would be very grateful for that) which I will then try to understand.
Anyways, my last attempt was this:
Calculating the current I:
After removing the R3 resistor, I am left with 2 parallel resistors R1 + R4 and R2 + R5, so I calculated the current that goes through the lower half of the circuit like this:
Ix = U/R2 + R5
Then the upper current:
Iy = U/R1 + R4
And because the I coming from U is split between the upper and lower part of the circuit, the final I would be Ix + Iy.
Calculating the Ut:
Then using the current, I would determine UR1, UR2, UR4 and UR5.
Then UA = U - UR1 and UB = U - UR2
My final Ut would then be the difference: UA - UB
Calculating the Rt:
If I supress the source, I am left with a parallel circuit and I either put together R1 + R2 and R4 + R5 or R1 + R4 and R2 + R5.
My intuition tells me the first one but I have drawn the picture earlier with the second option and you said that was correct.
So I then do Rt = R14*R25/R14 + R25 to figure out Rt.
I have tried both ways but neither gave me an answer that would match the star delta method one.
I am however very close (I am supposed to be getting something like 0.22... and I am getting 0.20...).
I' d love to hear your thoughts!
Unfortunately we can't solve problems for you in that manner. It's against the forum rules to do the work for you or provide complete solutions. But we can give guidance, make suggestions, point out errors, and so forth.
Ix = U/R2 + R5
Iy = U/R1 + R4
Okay. You should insert parentheses to group terms in order to fix the order of operations so that there can't be misinterpretations:
Ix = U/(R2 + R5)
Iy = U/(R1 + R4)
and that would be correct.
Do you need that total I for anything? Certainly not for the potential calculations...
Calculating the Ut:
Overall you've got the right idea. But I'm concerned about some details:
You didn't explicitly specify a reference node, so It's hard to confirm your formulas. But something looks off to me since both R1 and R2 are connected to the "-" terminal of the voltage supply U and if you took that as your starting point a KVL walk from there through U to the terminals wouldn't pass through those two resistors.
Perhaps you should take your initial circuit diagram and indicate the currents and potential drops that you're using (their polarities in particular).
Calculating the Rt:
For two components to be in parallel both of their leads must be directly connected, nothing in between. For each of the components you need to be able to trace a path via wires only from one component to the other for both of their leads. Note that drawn placement or orientation on the page does not determine series or parallel... only the topology of the circuit counts. Components can be turned, moved, or otherwise mucked about with on the diagram so long as their node connections are not altered. When in doubt, number each node in the circuit and then list each component along with their node associations. Parallel components will have the same associations.
That doesn't look right (even taking into account the lack of parentheses). Go back to the figure in post #4. Once you've reduced R14 = R1||R4 and R25 = R2||R5, how are R14 and R15 connected? Going from terminal a to terminal b through R14 and R25 do you need to split the path or just carry on through them in a single path?
Hello there again qneill! Okay then, I will have to figure this out! : ) I must do this, it can't be that hard!
Nope I do not need the total I of course, I use the two separate Is to determine the Us.
I am glad I got that step right at least!
The way I figured out the walk was that I placed the reference point all the way down there, and did two walks.
On the first one I passed UR1 and on the second one UR2. Here I drew a picture:
http://s16.postimg.org/pfvzvw21x/walk.png
So if I added the R1 and R4 right in this picture http://s2.postimg.org/gohtw4evd/surpressed.png why couldn't I add R1 + R2 ? I mean they arent parallel, and the source is gone so it seemed more addable to me than R1 and R4 since the terminals seemed to me like they were blocking the way from R1 to R4.
And it would appear to me that R14 and R15 are parallel if I move the terminals from inside to the main line in the circuit.
But maybe I could add them first before I do that?
I am really not sure here, in the example form the professor, the resistors were parallel and it made some sense to me there.
Did you pencil in the potential polarities first? Your currents pass through the resistors in a certain direction, imposing a polarity. Also, the direction in which you "walk" through a source determines the sign of the potential change:
So, walking from your reference node at the bottom, through the source U and through R2 to terminal B you have:
UB = -U + UR2
You could also have taken the path to the right, passing only through R5:
UB = -UR5 = -Ix * R5
R14 feeds terminal A, while R25 feeds terminal B. So your diagram is not correct. Look again at the diagram in post #4.
In fact, you should take your original diagram (with R3 removed and the source suppressed), identify all the nodes and label them (use "A" and "B" for the nodes associated with the terminals). Then make a list of all the components with their node affiliations. That should allow you to pick out all the parallel components.
Once you've reduced the parallel opportunities (you should find R1||R4 and R2||R5 as we've seen), then draw the simplified circuit and do the same exercise on it. You should find NO new parallel opportunities.
Hey there again!
Sorry, forgot to draw the polarities, they are the exact opposite of the ones you added so I guess my equations should be correct then?
Now to figure out the resistance.
So do I need to calculate RA and RB separately because RB is not lying on the same line as the reference point like it was in the simple case I posted?
And then the final Rt will be the difference between RA - RB?
I think I am running out of ideas here.
If this is the case, then with the source removed, it will look like this? :
http://s3.postimg.org/q1sko9wrn/Untitled.png
And RA will then be equal to R1*R4/R1 + R4 and RB R2*R5/R2 + R5?
And Rt = RA - RB? Or do I add them?
Daeol said:
Hey there again!
I haven't checked, but the circuit is simple enough that that might be true. For more complex circuits, being casual with polarities almost always leads to incorrect results.
There's no one method. All that matters is that you calculate the resistance between terminals A and B when the source is suppressed. I gave you a method to find parallel component opportunities if they are not obvious by inspection. Have you tried that? After that it's a matter of re-drawing the circuit with the new parallel components in place, then further simplify.
Sometimes it can help to draw your circuit "from scratch" by taking your list of components with node associations and drawing from that information alone. Make dots on the page to represent nodes and then sketch in the components between nodes. With the source suppressed your circuit has only three nodes. Make sure that you can identify them!
Resistances are never combined by differences. They combine either in series (##R = R1 + R2 + ... + Rn##) or in parallel (##R = \frac{1}{\frac{1}{R1} + \frac{1}{R2} + ... + \frac{1}{Rn}}##)
Your diagram showed the resistances that lie between terminal A and your reference node. Clearly they can be combined in parallel to form a single resistance value between terminal A and the reference node. Fine. Call that RA if you wish. Now do the same thing for terminal B. Call the result RB. Re-draw your circuit with RA and RB in place. Then take a "walk" from terminal A to terminal B. How do RA and RB combine along that walk?
Daeol, you should strongly consider uploading your images to this site (via the UPLOAD icon) so that they can appear embedded in your post, rather than making everyone go to another site to view them.
They look linear to me but in that case, it does not fit with the star delta IR3 value.
However, I don't even know what the right values are I think.
Because from my star delta calculations, I got 122 for UR4 for example, but when using the method I described earlier with Thevenins theorem, I got 160. But when I think about it, the R3 was gone when calculating the voltage in the second case, so I suppose that is why?
I am really getting desperate... : /
And sorry about the pictures, will remember that next time!
How about I calculate the resistance between A and B direcntly like this?
Rt = (R1+R2)*(R4+R5)/(R1+R2+R4+R5)
I don't see what motivates that calculation. In any event, it is incorrect.
Look at the following diagram. The source has been suppressed:
Clearly, R1 and R4 are connected at node A. Clearly R1 and R4 are also connected at node C. If you have done the exercise of listing the components and their node associations you know this. So R1 and R4 are connected in parallel. Call their combined resistance R14.
The same is true for R2 and R5. Both are connected to nodes B and C.
So you have two parallel connected resistor pairs. Call their resultants R14 and R25. R14 connects between A and C. R25 connects between B and C.
So what's the resistance between A and B?
I would say series because that gives me the right result! At long last!
Thank you so much for all your help and patience! : )
So, let's go over this one more time,
After suppressing the source and removing R3, I have the picture you posted above.
Calculating the current and Ut:
The current that goes through R1 and R4 is U/(R1 + R4) and for R2 and R5 U/(R2 + R5).
From that it is then easy to get the voltage of each resistor and the easiest way to calculate Ut is either UR4-UR5 or UR2-UR1 according to Kirchhoffs laws.
However, each one gives a slightly different numeric value such as 104,523 and 104,524. Does that matter? Or is it okay?
Calculating the Rt:
RA = R1*R4/(R1 + R4)
RB = R2*R5/(R2 + R5)
Rt = RA + RB
Is that correct?
I don't recall you specifying any values for the components, so I can't say. Could be just rounding/truncation errors creeping into the results from rounding/truncation at intermediate steps.
Calculating the Rt:
Rt = RA + RB
Is that correct?
Looks good.
You are right. I did not specify any but in my calculations, it was just slightly different but I hope it does not matter as long as I got the method right.
I have 3 more problems to solve with circuits, 2 of them which I have not been introduced to yet and one the professor already showed us, although again, quite vaguely.
They all require different method to solve them so no more Thevenin but my question is, should I create a new thread for each one?
Or can I just post them to this one? I will start looking at the first one of them tomorrow.
Once more, I really appreciate your help : )
