Solve Impossible Integral: \int exp (-x^2) dx
7 replies · 5K views · last reply
Kawakaze
Hi guys,
I came across this in a textbook, it says its as good as impossible to integrate this expression. I've met a lot of smart guys on here, maybe someone can do it?
[tex]\int exp (-x^2) dx[/tex]
This is a well known case , integral that exists but doesn't have an analytical expression. You can try it in all mathematic software and see that they can compute it only numerically.
Hi Kawakaze! :smile:
Sorry, the only way is to look it up in tables of erf(x) (the "error function") … see http://en.wikipedia.org/wiki/Error_function" :wink:
(unless the limits are -∞ to ∞, or 0 to ±∞)
Liouville's Theorem (1835, Differential Galois Theory) states that if f(x) and g(x) are rational functions where f(x) is not identically zero and g(x) is non-constant then [tex]\int f(x) e^{g(x)} dx[/tex] is an elementary function if and only if there exists some rational function r(x) satisfying the equation [tex]f(x) = r'(x) +g'(x) r(x)[/tex]. Applied to this specific problem, the theorem states that [itex]\exp(-x^2)[/itex] has an elementary anti-derivative if and only if there is a rational function r(x) such that [tex]1= r'(x) - 2x r(x)[/tex]. It is possible to show that r(x) doesn't exist with a proof by contradiction. Maybe you or someone else wants to try it.
Well despite what i originally said wikipedia says there is an analytic expression with infinite terms though.
[tex]\int e^{-x^2}dx=\sum_{n=0}^{\infty}(-1)^n\frac{x^{2n+1}}{n!(2n+1)}+c[/tex]
The sum on the right is not considered an elementary function. Your book must have said that the integral is impossible to find * in terms of elementary functions*.
That's a standard Gaussian Integral
I2=∫e-x2∫e-y2
where y is just a dummy variable. Change to polar co-ordinates
r2 = x2+y2
dxdy=rdrdθ
I2=∫∫re-r2drdθ
which is trivial to calculate. You then take the square root of the answer.
I2=∫e-x2∫e-y2
r2 = x2+y2
dxdy=rdrdθ
I2=∫∫re-r2drdθ
Right. So you won't mind us giving us the value of
[tex]\int_0^1 e^{-x^2}dx[/tex]
if it is so trivial??
