Solve Impulse Question on Bullet Acceleration & Force
  • Thread starter Thread starter acsin92
    Impulse
The discussion centers on calculating various physics parameters related to a bullet penetrating a wooden block. The bullet's mass is 0.005 kg, and it travels at 400 m/s before stopping. The user proposes using specific equations for acceleration, force, time, and impulse, with initial calculations yielding an acceleration of 1,000,000 m/s², a force of 5000 N, a time of 0.0004 s, and an impulse of 2 Ns. There is some uncertainty about the validity of these large values due to the short time frame involved. The user seeks confirmation on the correctness of their calculations and the equations used.
acsin92
A bullet with a mass of 0.005 kg and moving with a speed of 400 m/s penetrates a distance of 0.08m into a wooden block firmly attached to the Earth. Assume that the force stops it is constant. Compute for:
a.) acceleration of the bullet
b.) accelerating force
c.) time of acceleration
d.) impulse of the bullet
I think I'll use
a=-Vi^2 / 2s.
for the acceleration of the bullet.
then for the acceleration of the bullet,
F=m(Vf-Vi)
then for the time of acceleration,
t = m(Vf-Vi) / F
am i right?
I think I'll use
a=-Vi^2 / 2s.
yes
then for the accelerating force [/color]of the bullet,
F=m(Vf-Vi)
No, what is Newton's second law?
t = m(Vf-Vi) / F
yes, (or use t = (Vf -Vi)/a , as a check)
am i right?
and part d?
a.) acceleration of the bullet = 1,000,000 m/s^2
b.) accelerating force = 5000N
c.) time of acceleration = 0.0004 s
d.) impulse of the bullet = 2 Ns
are these correct? I used the equations above. I'm in doubt whether this is correct because of those large numbers and for that small amount of time.
I used the equation of I=Ft for impulse.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
