Solve Java Selection Sort Issues | Hi, I'm Working on Code
  • Context: Java
  • Thread starter Thread starter tshet
    Java Sort
4 replies · 2K views
tshet
Hi, I'm currently working on my selection sort code, and I've come across some problems.
Java:
i
import java.util.Arrays;
import java.io.*;
public class SelectionSort
int a[];
static int n;
public static void main(String[] args)
int array[] = { 5,3,9,7,1,8 };
n = 6;
System.out.println(""+Arrays.toString(Sort(array)));
public static int[] Sort(int[] arr)
int t, min;
for(int i=0;i<n-1;i++)
min = i;
for(int j=i+1;j<n;j++)
if(a[min]>a[j])
min = j;
if(min!=i)
t = a[min];
a[min] = a;
a = t;
System.out.println(""+Arrays.toString(arr));
return arr;
Can someone please tell me what the problem is?
Well, I've taken the structure of my bubble sort and put it into my selection sort. I'm just trying to change the code for the actual selection part. I'm just getting simple mistakes now..
It's doubt that it's that easy. I put the code in my IDE and it highlights several problems such that it won't compile. What's the error that you're getting when you try to compile?
It's difficult for us to say what the problem is merely by looking at your code. Make it easier by giving us a clue about what you're seeing? Are you getting compile errors? (Another poster in this thread said that your code doesn't compile.) If it doesn't compile, what error message is the compiler giving you?
If the code compiles but throws and exception or otherwise doesn't behave like it should, give us that information, and in fact, any information that would help us help you.
