Solve Logarithmic Equation: Log _3(x-5) + Log _3(x+3)=2
  • Thread starter Thread starter Illuvitar
    Logarithmic
Illuvitar
##log _3\left(x-5\right) + log_3\left(x+3\right) = 2##
I'm having trouble with applying properties of logarithms to solve equations, I think misunderstanding something fundamental here, I get most of the questions right but there are a handful that I have no idea what I am doing. Please help.
I try to condense the logs into one with the product rule so:
##log_3\left(x^2-2x-15\right) = 2##
then I rewrite it in exponential form:
##3^2=x^2-2x-15##
Now I figured that getting rid of the logs would make this quadratic equation manageable but I am coming up nowhere near the right answer (I peaked, its 6).
If I add 15 to both sides I get:
##24=x^2-2x##
but I don't know what to do with the quadratic...I feel like I messed up trying to get rid of the logs but I can't really identify where I screwed up. I tried to rework it a couple times with different tricks but I still am nowhere close. Any help would be appreciated.
Quadratic formula?
Well I didn't use the quadratic formula but I did try factoring it after subtracting 24 from both sides but I got negative roots and I thought you couldn't have those in a logarithms domain? Sorry... I know this is easy math for a lot of you but I am teaching this to myself and am having a bit of trouble. Ill use the quadratic formula thanks.
Just to check, can you please show us the factorisation you did after subtracting 24? There should be one positive and one negative root.
Why can't you use the quadratic formula?
An alternative is simply to "complete the square":
For example, take ##x^2 +2x - 3=0##. I want to write this as ##(x +1)^2 + F=0## for a certain ##F##. Clearly ##F=-4##. So the equation becomes ##(x+1)^2 -4 = 0##. Thus ##(x+1)^2 = 4##. Hence, ##x+1 = \pm 4##.
Crap. I messed up on the factoring, I should have gotten (x-6)(x+4) but I wrote on my paper (x+6)(x+4). thanks.
And I guess I just didn't think to use the quadratic formula(or completing the square), usually when I use it I end up with complex roots and I think for logs I have to have real non-zero solutions. I'm not sure, I just started learning logs yesterday.
Oh and I have one more if you guys don't mind. This is one of the ones where I don't know where to start.
##log(x+4)= logx+log4##
I used the product rule to condense the right side
##log(x+4)=log(4x)##
but after that I have no idea what to do...
If the logs of two numbers are equal, then the two numbers are equal.
Also, it's a good idea right at the start, to indicate what numbers are allowed for each of the log expressions. In this problem, you must have x > - 4 for log(x + 4) to be defined, and you must have x > 0 for log(x) to be defined. Together, these mean that x > 0.
Move the logs to one side :smile: Also keep in mind that [itex]a^0=1[/itex] for any positive a.
Okay. So the equation becomes
##x+4=4x##
its not a quadratic so I can't factor it into two roots right? I am sorry I still don't know what to do from here...
If I move them to one side I get
##log(4x/x+4)=0## because of the quotient property right? but I don't know how to simplify it further.
And I am not sure I understand how I should use ##a^0=1##
its seems like the terms have an implied power of 1.
##x+4=4x##
Right, it's not a quadratic. Add -x to both sides. This is really a simple equation...
##e^0 = ...##
Alright sorry...
You have really made it complicated. Also, I think the fraction is intended to be ##\frac{4x}{x + 4}##, so you should have written it as 4x/(x + 4) if that's what you meant. Without the parentheses, knowledgeable people would interpret it as (4x/x) + 4.
Of course. x is the same as x1.
I woke up too early this morning to start answering questions. Clearly if
[tex]\log(a)=\log(b)[/tex] then a=b. Moving everything to one side, using a log property and then using the definition of logs as so:
[tex]\log(a)-\log(b)=0[/tex]
[tex]\log\left(\frac{a}{b}\right)=0[/tex]
[tex]\frac{a}{b}=1[/tex]
[tex]a=b[/tex]
Is just a long winded way of showing the same thing.
  • · Replies 39 ·
