Solve Mass-Spring System Vibration Free
17 replies · 5K views
viciado123
Vibration Free
Please, are correct?
[tex]m \frac{d^2x}{dt^2} + kx = 0[/tex]
Where frequency is
[tex]w = \sqrt{\frac{k}{m}}[/tex]
[tex]\frac{d^2x}{dt^2} + \frac{k}{m}x = 0[/tex]
The characteristic equation is:
[tex]r^2 + w^2 = 0[/tex]
[tex]r = +or- iw[/tex] where [tex]i^2 = -1[/tex]
Then
[tex]x(t) = C_1e^{iwt} + C_2e^{-iwt}[/tex]
Calculating I can get
[tex]x(t) = a1cos(wt) + a2sin(wt)[/tex]
Now, I need to do to get the following equation. how do I find?
[tex]x(t) = Acos(wt - \delta)[/tex] (I think this is the equation we need to get the free vibration)
Ya, it's correct, and
[tex] x(t) = a_1cos(wt) + a_2sin(wt) = A cos(wt - \delta)[/tex]
if you define
[tex] A \equiv a_1^2 + a_2^2[/tex]
and
[tex] \delta \equiv arctan(a_1/a_2)[/tex]
This is the equation of free vibration of an undamped single degree of freedom dynamic system with linear elastic stiffness.
if you define
and
Why if [tex]A \equiv a_1^2 + a_2^2[/tex] and [tex]\delta \equiv arctan(a_1/a_2)[/tex] we have:
[tex]x(t) = a_1cos(wt) + a_2sin(wt) = A cos(wt - \delta)[/tex]
What the calculations involved?
Use the multiple angle formula for cos, cos(a-b)=cos(a)cos(b)+sin(a)sin(b)
With
[tex]cos(a-b)=cos(a)cos(b)+sin(a)sin(b)[/tex]
[tex]x(t) = a_1cos(wt) + a_2sin(wt)[/tex]
I do not understand how to find [tex]A cos(wt - \delta)[/tex]
Have you tried rather than just staring at the formulas?
"cos(a-b)= cos(a)cos(b)+ sin(a)sin(b)" with "[itex]\omega t- \delta[/itex]" instead of a- b gives you [itex]Acos(\omega t-\delta)= Acos(\omega t)cos(\delta)+ A sin(\omega t)sin(\delta)[/itex].
In order to have that equal to [itex]a_1cos(\omega t)+ a_2sin(\omega t)[/itex], you must have [itex]a_1= A cos(\delta)[/itex] and [itex]a_2= A sin(\delta)[/itex].
Dividing the first equation by the second gives
[tex]\frac{A sin(\delta)}{A cos(\delta)}= tan(\delta)= \frac{a_2}{a_1}[/tex]
so [itex]\delta= tan^{-1}(a_2/a-1)[/itex].
Squaring and summing the two equations gives
[tex]a_1^2+ a_2^2= A^2 cos^2(\delta)= A^2[/tex]
so [itex]A= \sqrt{a_1^2+ a_2^2}[/itex].
BobbyBear didn't quite have those equations in his post.
Yes, thank you.
The general solution is
I find A with the initial conditions ?
[tex]x(0) = Acos(- \delta) = X_o[/tex]
[tex]x'(0) = -Awsin(- \delta) = V_o[/tex]
I'll be A in the function [tex]\delta[/tex] ?
Oopsie, I guess I tried to do it too quickly. HallsofIvy's relationships are the correct ones :)
And yes, on applying the initial conditions you obtain a 2 by 2 system (the one you wrote out), which you solve for A (the amplitude) and the angle [tex]\delta[/tex]
I could not find A
[tex]X(0) = Acos( - \delta) = X_o[/tex]
[tex]X'(0) = -Awsin(- \delta) = V_o[/tex]
[tex]\delta = tan^{-1} \frac{V_o}{X_o w}[/tex]
And A ?
Well, once you have [tex] \delta [/tex]
you can go to any of the two equations and get A, eg
[tex]A= X_0/cos(\delta) = \frac{X_0}{cos(arctan(V_0/X_0w))} = \frac{X_0}{X_0w/\sqrt{X_0^2w^2+V_0^2}} = \frac{\sqrt{X_0^2w^2+V_0^2}}{w}[/tex]
Sorry, I do not understand your calculation.
Acos(- \delta ) = X_o
[tex]A cos(\delta) = X_0 \rightarrow A = X_0 / cos(\delta)[/tex]
and
[tex]\delta = arctan(V_0/X_0w)<br /> [/tex]
so
[tex]cos(\delta) = cos(arctan(V_0/X_0w))<br /> [/tex]
yes?
(By the way, cos(-a) = cos(a) that's why I didn't bother with the minus sign)
and
so
yes?
Yes. Thank you
I got a doubt in the beginning.
After obtaining the characteristic equation
[tex]r = \pm iw[/tex] with [tex]i^2 = -1[/tex]
How do we know [tex]x(t) = C_1e^{iwt} + C_2e^{-iwt}[/tex] ?
Because the theory of differential equations tells us that the general solution of a homogeneous linear ordinary differential equation with constant coefficients is given by a linear combination of exponentials of the form: [tex] e^{rt}[/tex]
with r being the roots of the characteristic polynomial, which in this case are [tex]\pm iw[/tex]
Thank you very much. You know about damped in my other topic ?
Someone has a graphic example of the system to vibration free ?
To plot the graph using Maple 12, which values I use for [tex]k[/tex], [tex]x_o[/tex] and [tex]v_o[/tex]?
