Solve Mass Suspended from Uniform Boom
  • Thread starter Thread starter NikkiNik
    Mass Uniform
3 replies · 6K views
NikkiNik
A mass M=171 kg is suspended from the end of a uniform boom as shown. The boom (mass=83.0 kg, length=2.40 m) is at an angle θ=69.0 deg from the vertical, and is supported at its mid-point by a horizontal cable and by a pivot at its base. Calculate the tension in the horizontal cable.
http://i32.photobucket.com/albums/d2/NikkiNik88/staticsboom.gif
T=rsin(theta)
Theta = 69 deg, alpha=21 deg
mg(L/2)cos(theta) + Mg(L)cos(theta) + T(L/2)sin(alpha) = 0
When I solved for T I got 4169.25N but that is incorrect please help
Why are you using cosine for mg(L/2) and sine for the others, instead of the other way round? Think more carefully about which functions you should use.
Would I be using sine for the masses because they are vertical and cosine for the tension because it's horizontal? If that's the case, is the rest of my work correct if I switch sine and cosine?
Yes! So:
mg(L/2)sin(theta) + Mg(L)sin(theta) + T(L/2)cos(theta) = 0
The answer you get will be negative, but that's only because the tension acts to counteract the torque applied by gravity.
