Solve nxn Determinant Homework
  • Thread starter Thread starter cdummie
    Determinant
The discussion focuses on solving the determinant of an nxn matrix defined as D_n, where the matrix contains a specific pattern of 1s and 2s. The initial approach involved transforming the matrix by multiplying the last row by -1 and adding it to other rows, leading to a triangular form. However, this method was critiqued for incorrectly applying determinant properties, specifically regarding column exchanges and their impact on the determinant's sign. The correct approach involves recognizing the resulting matrix's structure after column exchanges, ultimately leading to the conclusion that D_n = (-1)^{\lfloor n/2 \rfloor}.
  • Understanding of determinants and their properties
  • Familiarity with matrix transformations and row operations
  • Knowledge of linear algebra concepts, particularly triangular matrices
  • Experience with mathematical proofs and problem-solving techniques
  • Study the properties of determinants, focusing on column exchanges and their effects
  • Learn about triangular matrices and how to compute their determinants
  • Explore advanced techniques in linear algebra for solving determinants of larger matrices
  • Investigate the implications of matrix transformations on determinant values
Students studying linear algebra, mathematicians solving determinant problems, and educators teaching matrix theory will benefit from this discussion.
cdummie
I have to solve the following determinant
## D_n=\begin{vmatrix} 1 & 1 & 1 & \cdots & 1 & 1 & 1 \\ 1 & 1 & 1 & \cdots & 1 & 2 & 1 \\ 1 & 1 & 1 & \cdots & 2 & 1 & 1 \\ \vdots & \vdots & \vdots & \ddots & \vdots & \vdots & \vdots \\ 1 & 2 & 1 & \cdots & 1 & 1 & 1 \\ 1 & 1 & 1 & \cdots & 1 & 1 & 0 \end{vmatrix} ##
So my idea was to multiply the last row by -1 and add it to every other row, that way, i had the following determinant:
##D_n= \begin{vmatrix} 0 & 0 & 0 & \cdots & 0 & 0 & 1 \\ 0 & 0 & 0 & \cdots & 0 & 1 & 1 \\ 0 & 0 & 0 & \cdots & 1 & 0 & 1 \\ \vdots & \vdots & \vdots & \ddots & \vdots & \vdots & \vdots \\ 0 & 1 & 0 & \cdots & 0 & 0 & 1 \\ 1 & 1 & 1 & \cdots & 1 & 1 & 0 \end{vmatrix} ##
So i have determinant with all zeros above diagonal, so solution to this should be product of all elements of diagonal (i should keep in mind that sign changes since this isn't "regular" diagonal), so i ended up with: ## D_n=(-1)^{\frac{n(n+1)}{2}} ##. Is this correct?
I don't think you are correct. Unless I'm wrong ##D_3 = -1##, but with your answer you get 1.
You don't change the determinant by adding to a column a multiple of another column, and you multiply the determinant by ##-1## by exchanging 2 columns. So after your transformation, you exchange columns ##(i,n+1-i)## for ##i = 1...\lfloor n/2 \rfloor## so that you have the determinant of a diagonal (EDIT: TRIANGULAR sorry) matrix that has only 1's on the diagonal, and ##\lfloor n/2 \rfloor## transpositions.
geoffrey159 said:
So after your transformation, you exchange columns ##(i,n+1-i)## for ##i = 1...\lfloor n/2 \rfloor## so that you have the determinant of a diagonal matrix that has only 1's on the diagonal, and ##\lfloor n/2 \rfloor## transpositions.
I don't understand what you mean, could you explain me this part?
In your attempt to a solution, you wrote
##D_n= \det(C_1,...,C_n) = \begin{vmatrix} 0 & 0 & 0 & \cdots & 0 & 0 & 1 \\ 0 & 0 & 0 & \cdots & 0 & 1 & 1 \\ 0 & 0 & 0 & \cdots & 1 & 0 & 1 \\ \vdots & \vdots & \vdots & \ddots & \vdots & \vdots & \vdots \\ 0 & 1 & 0 & \cdots & 0 & 0 & 1 \\ 1 & 1 & 1 & \cdots & 1 & 1 & 0 \end{vmatrix} ##
Now each time you exchange two columns, you multiply the determinant by -1. So that by permuting columns ##i## and ##n+1 - i## for all ##i = 1... \lfloor n/2 \rfloor##, you get
##D_n = (-1) ^ {\lfloor n/2 \rfloor } \det(C_n,C_{n-1},...,C_1) ##
and ## \det(C_n,C_{n-1},...,C_1) ## is very easy to compute.
  • · Replies 34 ·
