A Solve PDE w/ Comsol 5.3: Numerical Solution & Time Evolution
umby
TL;DR Summary
Numerical solution of a partial differential equation containing the derivative of the unknown at a point
What is the best way to solve numerically the following equation using Comsol 5.3.
##\frac{\partial T}{\partial t}=\frac{\partial ^2T}{\partial x^2}+\text{St}\left[1+\left(\frac{\partial T}{\partial x}\right)_{x=0}\right]\frac{\partial T}{\partial x}##
##T(0,t)=1##
##T(\infty ,t)=0##
##T(x,0)=\exp \left(-\frac{x^2}{\pi }\right)-x \text{erfc}\left(\frac{x}{\sqrt{\pi }}\right)##
where ##\text{St}## is a parameter which can varies from 0.01 to 100.
I am particularly interested in following the evolution of ##\text{St}\left[1+\left(\frac{\partial T}{\partial x}\right)_{x=0}\right]## with time.
Thanks in advance.
Be care. This is not a PDE at all. Even the correctness of such a problem needs for a separate study.
You mean because of the coefficient of the derivative of ##T## with respect to ##x##? Maybe differential relation is better? Can you help me please in determining the correctness of this problem?
I mean the term
$$\frac{\partial T}{\partial x}\Big|_{x=0}$$
Exsactly what I was mentioning, thank you for point it out. Coefficients cannot be function of the unknown, only of the indipendent variables, in my case ##x## and ##t##.
Can you please tell me more about the matter of its correctness?
You can probably write a finite difference code easier than using comsol. Then you can insert the nonlinear part of the PDE with ease.
Likes umby and berkeman
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
