Solve Temperature Question: Find a, b & k
  • Thread starter Thread starter Burjam
    Temperature
13 replies · 3K views
Burjam
The temperature, T, in ºC, of a yam put into a 200ºC oven is given as a function of time, t, in minutes, by
T=a(1-e-kt)+b
a. If the yam starts at 20ºC, find a and b.
b. If the temperature of the yam is initially increasing at 2ºC per minute, find k.
Given in problem.
I'm not really sure how to set up this problem to do part a. I think if I had a and b I'd be able to do part b with some derivatives and algebra but I just can't figure out how to get there. My instincts are telling me to set T = 20 = a(1-e-kt)+b but I don't know how to approach this from here.
For part a set time = 0. What happens to e^-kt then? Can you solve for one of the constants?
When t=0, e=1 and therefore a=0. Therefore b=initial T which in the case of a is 20. Ok great. But what do I do to get a? I think I need to set T=20 but I don't know what I need to set t equal to. I know I can't use zero, but aside from that I don't know what to do.
Generalizing your statement, you're saying that if any number x is multiplied by zero, that number x is zero.
Do you see a problem with this?
If you have x*0, does this imply that x = 0?
Also, is e a constant or a variable?
I'm saying that at t=0, a(1-e-kt) will equal zero because e0=1, 1-1=0 and a*0=0.
I wasn't trying to imply that.
e is the constant Euler's number.
a*0 indeed equals 0, but we're deviating from the original problem. Are there other parts to the original equation even when you substitute 0 in for time and 20 degrees C in for the temperature?
Right, and e = 2.71 (approximately). Not 1.
What do you mean by "other parts"?
But if we're setting t=0, it will be e-k*0. -k*0=0 so it will be e0=1.
What happened to the variables you were solving for? Surely if they all canceled out then this would be a bad question on the part of the teacher, right?
e^0 = 1.
You stated e = 1.
Wait what? What do you mean "what happened to the variables you were solving for?" I was only trying to say everything but b is canceled out when t=0. Surely you must see that.
Qube said:
e^0 = 1.
You stated e = 1.
Ok that was a false. Take it as e0=1
Ok. So you've got b. Now what happens if t is very, very large?
T = a(y) + b, where y is substituted in for whatever function that a was multiplied by.
If y = 0, then
T = a(0) + b
Do you see what happens (contrary to what you think?)
When t gets very large, e-kt approaches 0. So the equation becomes a(1-0)+b=T. This is simplified to a+b=T where b is the initial temperature and T is the final temperature. Therefore a=T-b.
If y = 0, then
T = a(0) + b
Yes I get it. But in this scenario a(0)=0. I just simplified it.
Yes, that's it. t=0 gives you one constant and t=infinity gives you the other one. Now you just need to find k. You are given dT/dt=2 at t=0. So?
Solving for k I get 1/90, which appears to be the right answer in the back of the book. Along with my answers for a and b. Thanks.
