Solve the first order hyperbolic equation
32 replies · 5K views · last reply
andrey21
3 du/dx + 2x du/dt =2u
With initial condition: u(x,0) = 2x+4
My attempt at a solution
I usually adopt the method of characteristics:
dx/a = dt/b = du/c
So from the above:
a=3, b=2x and c=2u
am I on the right track here?
I do this in a slightly different way, my characteristic equations are:
[tex] \dot{x}=3,\quad\dot{t}=2x,\quad \dot{u}=2u[/tex]
Where the dot denotes differentiation to the characteristic variable, [itex]s[/itex]. I write the cauchy data as:
[tex] t(s=0)=0,\quad x(s=0)=r,\quad u(s=0)=2r+4[/tex]
Then just re-arrange to get rid of s and r and that will be your solution. I posted some notes on this in https://www.physicsforums.com/showthread.php?t=467445
Thank you hunt_mat. I shall read through ur notes. Is the method I was using incorrect for this question then?
Not an incorrect method, you can get the solution that way, I just think that the solution method that I presented is far easier to implement and you know if you're making a mistake or not.
So from what u have said, will the quotient of the characteristics be
dt/dx = 2x/3 du/dx= 2u/3
I think so, yes. To be perfectly honest, I was never really happy doing things this way.
Are u referring to the method I have adopted? Sorry for the confusion, I'm just anxious to answer this question.
So far, I think you're doing fine, but I haven't much experience with the method you're adopting. I have a book with it in though, so I will keep helping you with this method.
Ok hunt_mat I appreciate your help, now here's where I get stuck:
Integrating du/dx=2u/3?
So you have computed the characteristics which are given as [itex]3t-x^{2}=k[/itex] where [itex]k[/itex] is a constant, you know that [itex]u[/itex] is a constant on these characteristics, and you know that characteristics curve passes through the point [itex](t,x)=(0,r)[/itex], what will [itex]u[/itex] be at this point?
I'm a little confused how u got 3t-x2=k?
But will u(r,0) =2r+4
Because I solved the equation:
[tex] \frac{dt}{dx}=\frac{2x}{3}[/tex]
You are right with the second part.
Yes sorry its because I had it in the form:
t = x2 /3 +K
Ok so given u, where do I go next?
I still need to solve du/dx correct?
Now you need to compute K, you know that the characteristic passes through the point [itex](t,x)=(0,r)[/itex], so you can use that to compute K. Then you need to integrate your equation for u and use that fact that at the point [itex](t,x)=(0,r)[/itex], [itex]u=2r+4[/itex], so all you have to do is substitute for r.
So establishing K:
t = x2 /3 +K
0= r2 /3 +K
K=-r2 /3
Therefore:
t = x2 /3 - r2 /3
Correct??
Good so far. Now do the same thing for [itex]u[/itex] and you should end up with a function with x's and r's in, and now you know an equation for r.
So the next step is to do:
du/dx where u = 2r+4
so u = 2rx +4x
Is this correct??
No, you have an equation for u of the form:
[tex] \frac{du}{dx}=\frac{2u}{3}[/tex]
Solve that. You will have a constant to compute, that is when you use the initial condition you were talking about.
Ok this is the part I can't get past:
du/dx= 2u/3
I'm nt sure how to solve the above:
You integrate it like any other equation:
[tex] \log u-\log u_{0}=\frac{x^{2}}{3}[/tex]
Now we know that at the point [itex](t,x)=(0,r)[/itex], the solution is [itex]u_{0}=2r+4[/itex], so insert this into the equation and you will be left with an equation with lots of x's and r's, well you know an equation for r...
So substituting u0=2r+4 into:
logu-logu0 = x2/3
logu-log(2r+4)=x2/3
Not quite, You need to evaluate everything at the point [itex](t,x)=(0,r)[/itex], I note that you have done nothing about te x...
It would have been better to have written the solution as:
[tex] \log u=\frac{x^{2}}{3}+c[/tex]
Then to find c, just evaluate the equation at the point [itex](t,x)=(0,r)[/itex]
Yes, you also know what value of u at this point as well [itex]u=2r+4[/itex] and therefore
[tex] \log (2r+4)=\frac{r^{2}}{3}+c[/tex]So now you know what c is in terms of r, and you know what r is in terms of t and x, you can write down the solution.
So
c= log (2r+4) - r2/3
So
log u = x2/3 + log (2r+4) - r2/3
Yey, and now you know what r in terms of t and x are, substitute these in and you will have your solution.
So:
t = x2 /3 - r2 /3
r2 /3 = x2 /3-t
r2 = x2 -3t
r = SQRT (x2 -3t)
Good so far, remember there is an associated [itex]\pm[/itex] along with the answer. You have to decide which it is, but this shouldn't be too hard.
So :
r = [itex]\pm[/itex]SQRT (x2 -3t)
What is the next step?
