Solve the given simultaneous equation
  • Thread starter Thread starter chwala
32 replies · 4K views · last reply
chwala
Solve for ##x## and ##y## given;
##\sqrt x+ y=7##
##x+\sqrt y=11##
Simultaneous equations
I saw this problem on you tube ... The working to solution is much clear to me. Find the link here;
I am now trying to look at an alternative approach. My thinking is as follows;
##\sqrt x=7-y##
##x=(7-y)^2##
##(7-y)^2+\sqrt y=11##
##49-14y+y^2+\sqrt y=11##
i then let ##\sqrt y=m## giving me,
##m^4-14m^2+m+38=0## at this point i am now exploring ways of solving quartic equations...looking at it...then will respond on my finding...i hope i am on the right path...
drmalawi said:
What is the point of this thread?
Am I on the right path? My post is clear. I am exploring on alternative approach.
chwala said:
My post is clear
There was no question.
I can give you a hint regarding the quartic equation. Can you find a simple positive m-value which will solve it?
Also, you can with derivative method figure out how many positive roots that quartic equation will have.
You can also use that ##m < 7## to pinpoint down the only solution you care about in that quartic equation.
Yes, I am looking into this ...looking at the numerical methods...I'll get back once done...
I just solved it following your work with no aid of any calculator.
Was kinda fun :)
  • Haha
EDITED
Is an algebraic solution essential? Can I point out (if not already evident) that the problem can be solved using some 'guesswork'.
Click on the spoiler below for hints...
From inspection:
- x and y look likely to be not only integers but also perfect squares; we can try this to see where it leads
- values of 0 or 1 for x and y are easily excluded;
- y must be less than 6 giving a solution for y.
I noticed a mistake in the video...on the factorisation part; ought to be
##(\sqrt x-\sqrt y)(1-\sqrt x+\sqrt y)=-4## ...
And it looks like trial and error approach as the method on the video assumes solutions then works backwards to determine the value of variables ##x## and ##y##. I would rather a step-step working to solution. I will look at this today...
There are various techniques in solving quartic equations; phew a bit technical...Ferrari method, Durand- Kerner method ...need to read on them.
Delta2 said:
This polynomial we end up with $$m^4-14m^2+m+38$$ is very interesting, it has 4 roots ALL real...
I have seen all the ##4## roots with help of calculator...
ie ##-3.2831859, -1.8481265, 2 ## and ## 3.1313125##
Was kinda fun :)
Arrrrrrgh! I can now see that we can get the roots by using Factor theorem! Eeeeeeeeish!
  • Haha
I wrote that in post #4, don't you read the replies?
You first try with some solutions, you must have that 0 < m2 < 7, so try with some solutions for m.
You will find pretty quick that m = 2 works.
Then do polynomial division to get a cubic polynomial.
Show that the resulting polynomial does not equal zero for any positive m less than sqrt(7), I used some basic curve sketch analysis with derivative method.
What is so interesting with a quartic polynomial with four real roots?
Well I don't know to be honest, for some reason my intuition told me that most polynomials of high degree have at least one complex root.
I got it! I will post my step-step solution later in the day...I used the quartic approach- converted to cubic terms...with some algorithm involved. Bingo talk later...
This approach is straightforward man...i will post the approach that is used generally for quartic equations ..cheers
How do you compare the amounts of polynomals to quantify "most"?
Yes it is, I give my 16-17y old students similar problems which are solved using this approach.
Pure intuition, there are infinite polynomials but my intuition told me at at least half of them have a complex root.
chwala said:
Homework Statement:: Solve for ##x## and ##y## given;
##\sqrt x+ y=7##
##x+\sqrt y=11##
Relevant Equations:: Simultaneous equations
##\sqrt x=7-y##
##x=(7-y)^2##
We have;
On Using the approach given on this link https://www.1728.org/quartic2.htm
We shall have;
##f=-14##
##g=1##
##h=38##
Our cubic equation is;
##y^3-7y^2+\dfrac{44}{16}y-\dfrac{1}{64}=0##
On solving, we have
##y_1=6.583##
##y_2=0.412##
##y_3=0.0058##
giving us;
##p=2.566##
##q=0.6419##
##r=-0.0758##
substituting into the equations, we end up with;
##x_1=p+q+r-s=3.132##
##x_2=-p+q-r-s=-1.8483##
##x_3=-p-q+r-s=-3.2837##
##x_4=p-q-r-s=1.999999≅2## which is the envisaged value that we are looking for...from here the working to solution will follow...
drmalawi said:
how come you don't get exactly 2?
The approach is an approximate method (Numerical method) and not exact.
There are uncountably-many polynomials over the Reals, uncountably many with Complex roots( degree 2 or higher) ; those that are multiples of ##x^2+a ; a>0## alone are enough*, and uncountably-many with Real roots: ## ( x-r_1)(x-r_2)(x-r_3)(x-r_4); r_i \in \mathbb R##
*Similar argument if you want all roots to be Real.
I'd suggest in general to get a feel for it, as someone had suggested. And, maybe too, a more geometric approach using parabolas ( after squaring; set ## \sqrt u:= u, etc), though you'd have to go back-forth in the change of variables.
Hmm, can we say that the probability a random polynomial to have only real roots is 50%? Hard though to imagine how we define this probability as if we try to define it as a fraction, both the numerator and the denominator are uncountable many...
I made wolfram draw graphs of y=11-x^2 and x=7-y^2 where ##\sqrt{x},\sqrt{y}## in the problem statement is transferred to x, y.
I could confirm that there is only one solution for x,y>0, obvious x=3, y=2.
Equation for x is
[tex](11-x^2)^2=7-x[/tex]
[tex]x^4-22x^2+x+114=0[/tex]
[tex](x-3)(x^3+3x^2-13x-38)=0[/tex]
malawi_glenn said:
How do you compare the amounts of polynomals to quantify "most"?Yes it is, I give my 16-17y old students similar problems which are solved using this approach.
Descarte's Rule Of Signs.
Yeah but we do this in context with derivative of polynomial functions.
But thanks for the reminder! That is very useful trick.
Not without specifying a probability distribution on the polynomials. The result will depend on the distribution you impose.
Since both sets are aleph one, it is possible to construct a bijection between them.
