Solve the given trigonometry problem
  • Thread starter Thread starter chwala
    Trigonometry
10 replies · 2K views · last reply
chwala
See attached
Trigonometry
text solution here;
I was solving this today...got stuck and wanted to consult here...but i eventually found the solution...any insight/alternative approach is welcome...
My approach;
##\sin^2y+ cos^2 y= 2a^2-2a \sin x - 2a\cos x+1##
It follows that,##2a(\sin x + \cos x)=2a^2##
##\sin x+\cos x=a##
cheers.
Good job :thumbup:
I would just add a short conjecture. x and y are exchangeable in the formula given and
[tex]\sin x+\sin y + \cos x + \cos y=2a[/tex]
So we may guess
[tex]\sin x+\cos x = \sin y + \cos y=a[/tex]
chwala said:
sin⁡x+cos⁡x=a
By squaring
[tex]2 \sin x \cos x = a^2-1[/tex]
So[tex]x,y=\theta, \frac{\pi}{2}-\theta[/tex]where
[tex]\theta= \frac{1}{2} \sin^{-1}(a^2-1)[/tex]
anuttarasammyak said:
By squaring [tex]2 \sin x \cos x = a^2-1[/tex] So[tex]x,y=\theta, \frac{\pi}{2}-\theta[/tex]where [tex]\theta= \frac{1}{2} \sin^{-1}(a^2-1)[/tex]
Your solution is quite interesting.
Of course, the problem stated in the OP only asked that ##\sin x +\sin y ## be given in terms of ##a## .
... but to pursue your solution further:
Since ##\displaystyle \sin 2x = a^2-1##, the range of values for ##a## is limited if there is to be any real solution for ##x##..
I solve it in a different way.
I get ##\sin x+\cos x = \sqrt 2##. Can someone tell me where am I mistaken?
View attachment 316966I get ##\sin x+\cos x = \sqrt 2##. Can someone tell me where am I mistaken?
Mythoughts on this...
We know that
##\sin x + \sin y = 2 \sin \dfrac {x+y}{2} ⋅ \cos \dfrac {x-y}{2}=a##
and
##\cos x + \cos y =2 \cos \dfrac{x+y} {2}⋅\cos \dfrac {x-y}{2}=a##
##⇒4⋅\sin^2 \left[\dfrac{x+y}{2}\right] ⋅ cos^2 \left[\dfrac{x-y}{2}\right]=a^2##
##⇒4⋅\cos^2 \left[\dfrac{x+y}{2}\right] ⋅ cos^2 \left[\dfrac{x-y}{2}\right]=a^2##
on adding the two we end up with;
##cos^2 \left[\dfrac{x-y}{2}\right]\left(4⋅\sin^2 \left[\dfrac{x+y}{2}\right]+4⋅\cos^2 \left[\dfrac{x+y}{2}\right]\right)=2a^2##
##4⋅cos^2 \left[\dfrac{x-y}{2}\right]=2a^2##
##cos^2 \left[\dfrac{x-y}{2}\right]=\dfrac{2a^2}{4}##
##⇒cos\left[\dfrac{x-y}{2}\right]=\dfrac{a}{\sqrt{2}}##
Therefore on substituting back to our equation;
##2 \sin \dfrac {x+y}{2} ⋅ \cos \dfrac {x-y}{2}=a##
and
##2 \cos \dfrac{x+y} {2}⋅\cos \dfrac {x-y}{2}=a##
we get;
##2 \sin \dfrac {x+y}{2} ⋅ \dfrac{a}{\sqrt{2}}=a##
##2 \cos \dfrac{x+y} {2}⋅\dfrac{a}{\sqrt{2}}=a##
##⇒\sin \dfrac {x+y}{2}=\dfrac{\sqrt{2}}{2}##
##⇒\cos \dfrac {x+y}{2}=\dfrac{\sqrt{2}}{2}##
##⇒x+y=\dfrac{π}{2}##
Let ##x=y## then ##x=y=\dfrac{π}{4}##
##\sin x +\cos x=\sin \dfrac{π}{4} +\cos \dfrac{π}{4}=\sqrt{2}##
but;
##⇒\cos\left[\dfrac{x-y}{2}\right]=\dfrac{a}{\sqrt{2}}##
since ##x=y## then;
##1=\dfrac{a}{\sqrt{2}}##
##⇒a=\sqrt{2}##
Therefore;
##\sin x + \cos x= a##
SammyS said:
Since sin⁡2x=a2−1, the range of values for a is limited if there is to be any real solution for x..
For real x
[tex]0 < |a| \leq \sqrt{2}[/tex] as a ##\neq## 0 in the problem statement.
I wonder whether and why sign of a does not matter with the solution. So as another way without squaring,
[tex]\sqrt{2}\sin(x+\frac{\pi}{4})=a[/tex]
[tex]x=\sin^{-1}\frac{a}{\sqrt{2}}-\frac{\pi}{4}[/tex]
with y
[tex]x,y=\sin^{-1}\frac{a}{\sqrt{2}}-\frac{\pi}{4},-\sin^{-1}\frac{a}{\sqrt{2}}+\frac{3\pi}{4}[/tex]
where sign of a matters.
[tex]x-y=\pi[/tex]
,which gives a=0 the prohibited value, does not have AND relation but OR relation with
[tex]x+y=\frac{\pi}{2}[/tex]
,which allows a to be variable, in getting the solution.
We know that
and
and
we get;
but;
since ##x=y## then;
##⇒a=\sqrt{2}##
Therefore;
That is fine, but where am I mistaken in my solution in post #5 above?
You get ##cos\left[\dfrac{x-y}{2}\right]=\dfrac{a}{\sqrt{2}}##.
But I get ##cos\left[\dfrac{x-y}{2}\right]=0##.
We are both using correct math. But one of us has got to be wrong.
I agree it looks like I am. I just want to know where.
I paste my solution again. Please let me know when you get the time.
Fine. Let us investigate
[tex]x-y=\pi[/tex]
[tex]a=\sin x+\sin y=\sin (\pi+y)+\sin y = -\sin y + \sin y =0[/tex]
but the problem says ##a \neq 0##. So we should avoid it and go to another possibility that you wrote after OR in your last line. This was a repeat of post #8.
Correct. Please carry on.
You have $$\begin{align} & 2\sin\left(\frac{x+y}{2}\right) \cos\left(\frac{x-y}{2}\right)=a \nonumber \\ & 2\cos\left(\frac{x+y}{2}\right) \cos\left(\frac{x-y}{2}\right)=a \nonumber
\end{align}$$If you divide the top equation by the bottom, you get $$\tan\left(\frac{x+y}{2}\right)=1 \implies \frac{x+y}{2}=\frac{\pi}{4}.$$ Explore where that takes you.
