Solve Trebuchet Efficiency Mystery
To calculate the energy efficiency of a trebuchet, the user has determined the theoretical yield of gravitational potential energy (10.05 J) and the actual kinetic energy output (43.28 J). The calculated efficiency appears to be 430%, which raises concerns about the accuracy of the results. The discussion suggests using a simpler method for efficiency calculation based on the actual measured range compared to the theoretical range. It emphasizes that efficiency should be calculated as work in divided by work out, indicating that the current approach may have errors in the assumptions or calculations.
thua
I've calculated the time, the distance, the height of the counterweight before launch, the mass/weight, and I need to calculate the energy efficiency.
How to go about it?
h = 0.71 m
m = 1.445 kg
g = 9.8 m/s^2
t = 0.7 s
x = 4.44 m
Eg = mgh
Vix = x/t
y = Viy(t) + (1/2) a(t)^2
Ek = (mv^2)/2
THEORETICAL YIELD:
h = 0.71 m
m = 1.445 kg
g = 9.8 m/s^2
Eg = mgh
= (1.445 kg)(9.8 m/s2)(0.71 m)
= 10.05 J
ACTUAL YIELD:
t = 0.7 s
x = 4.44 m
Vix = x/t
= (4.44 m)/(0.7 s)
= 6.34 m/s
0.71 m = Viy(0.7 s) + (1/2) (-9.8 m/s2)(0.7 s)^2
Viy = 4.44 m/s
Vi^2 = (Vx)^2 + (Viy)^2
Vi^ = (6.34 m/s)^2 + (4.44 m/s)^2
Vi= 7.74 m/s
Ek = (1/2) mv^2
= (1/2) (1.445 kg)(7.74 m/s)^2
= 43.28 J
43.28 J / 10.05 J = 430%
I don't think my trebuchet is 430% efficient.
What did I do wrong?
Efficiency is work in/work out
An easier way to find trebuchet efficiency (all credit goes to Rom Toms http://www.trebuchet.com/):
Actual measured range in meters /theoretical range= efficiency
theoretical range in meters= 2 * (counterweight in kg * counterweight drop in meters)/ weight of projectile in kg
