Solve Tricky Integration: ##\frac{20\ln{(t)}}{t}##
  • Thread starter Thread starter squenshl
    Integration
The discussion revolves around solving the integral of the function ##\frac{20\ln{(t)}}{t}##, focusing on integration techniques and approaches.
  • Participants discuss whether integration by parts is the best method or if a simple u-substitution might be more effective. There are varying opinions on the simplicity of different approaches, and some participants express uncertainty about the setup and assumptions involved.
Multiple methods are being explored, including integration by parts and u-substitution. Some participants have offered guidance on the approaches, while others have raised questions about clarity and assumptions in the original problem statement.
There are mentions of potential ambiguities in the expression and the need for a constant of integration, as well as concerns about missing details in the original problem setup.
squenshl
How do I solve ##\frac{20\ln{(t)}}{t}##?
Is it easier to calculate this without integrating by parts?
I'm not sure where to start.
Solving by integration by parts is easy - very few lines. I can't think of an easier way.
There is an easier way. Try a simple "u-substitution".
You have ##f\cdot f'## which is half of ##(f^2)'##. Done.
I like the simplicity, but shouldn't it be just half of ##(f^2)## ?
edited: forgot the "half of"
##f^2## is the solution after integration, but I said ##f \cdot f' = \frac{1}{2} \cdot (f^2)'## for the integrand. Of course this all is a bit sloppy: no integration boundaries or the constant, no mentioning of ##\ln |x|## in the OP and no ##dt 's##.
Agreed. Thanks for clearing that up.
Substitute ##u = \ln t, du = \frac {1}{t}dt##
Thanks everyone. The solution is ##10\ln{(t)}^2##.
You might like to remove an ambiguity.
Is that the natural log of the square of t, or is it the square of the natural log of t ?
Also, I suspect that you need to include a constant of integration .
Typically for integrals involving ln in a typical calculus course...
Always try u sub. If that does not work, then integration by parts. Keep this in mind.
  • · Replies 26 ·
  • · Replies 54 ·
17K
