*solved*Particle moving along a parabola
  • Thread starter Thread starter rxh140630
    Parabola
The discussion revolves around a particle moving along a parabolic path defined by the equation y = x^2. Participants are exploring various aspects of the problem, including potential solutions and the implications of physical forces such as gravity.
  • Participants discuss the trivial and non-trivial solutions to the problem, questioning whether additional solutions exist beyond those provided in the textbook. There is also exploration of the role of gravity and whether it is necessary for the problem. Some participants suggest parameterizing the curve and consider the implications of changing coordinates with respect to time.
The discussion is active, with participants raising questions about the assumptions made in the problem statement and the clarity of the textbook. Some guidance is offered regarding parameterization and implicit differentiation, but there is no explicit consensus on the best approach or the completeness of the solutions discussed.
Participants note the lack of detail in the problem statement and express frustration over assumptions made by the author. There is mention of terminology that may indicate the textbook is outdated, which could affect understanding.
rxh140630
A particle is constrained to move along a parabola whose equation is y=x^2. At what point on the curve are the abscissa and the ordinate changing at the same rate?
x^2=y, dx/dy= 2x
Would the trivial solution be x=0,y=0?
Non trivial:
let [itex]y=x^2[/itex]
[itex]\frac{dy}{dx}=2x, \frac{dx}{dy} = \frac12y^{-\frac12}[/itex]
[itex]x=\frac14 y^{-\frac12}[/itex]
here x=1 and y = 1/16 is a solution
but my book says the answer is x=1/2 and y=1/4
this is one answer that you get with the equation I derived, but I feel like it's not the only answer. Am I missing something?
Don't you need something like a force of gravity here?
No clue, it's a calculus book, I'm guessing they decided to remove gravity from the equation.
  • Sad
Perhaps it doesn't matter whether the particle is accelerating or not?
What about parameterising the curve? I assume "changing at the same rate" means with respect to time.
Yeap, no mention of accelerating, I don't really know what that is. That's just the derivative of velocity right? It doesn't mention velocity or acceleration. Just how the two coordinates change with respect to each other, which I guess implies velocity? I need to start reading a physics textbook.
Yes, I believe changing at the same rate means with respect to time. I wrote out the whole question word for word as per the book. I wish the author was a tad more detailed and made less assumptions in his questions.
I had to look up "abscissa" and "ordinate" (and found they mean ##x## and ##y##), so perhaps this is a book from a bygone era. And I promptly forgot which one is which!
That said, you should parameterise the curve in terms of ##t##.
PeroK said:
I had to look up "abscissa" and "ordinate" (and found they mean ##x## and ##y##), so perhaps this is a book from a bygone era. And I prompty forgot which one is which!
Hmm actually I think implicit differentiation is the easiest way to do this problem.
it gives you the result x=1/2 and y=1/4, the books answer
rxh140630 said:
... Yes, I believe changing at the same rate means with respect to time. I wrote out the whole question word for word as per the book. I wish the author was a tad more detailed and made less assumptions in his questions.
Could it simply be the point of the curve around which Δx≈Δy?
If so, that would the point at which the slope of a straight line tangent to the curve equals 1, I believe.
  • · Replies 25 ·
