Solving a Linear Homogeneous Recurrence Relation
The discussion revolves around solving the linear homogeneous recurrence relation an - 5an-1 + 6an-2 = 0 with initial conditions a0 = 1 and a1 = 3. Participants explore the process of factoring the polynomial and identifying the characteristic roots, which are found to be t=2 and t=3. The general solution is established as a_n = A*2^n + B*3^n, and the constants A and B are determined using the initial conditions. The final solution is confirmed as a_n = 3n, validating the calculations. The importance of understanding the recurrence relation's structure and the role of initial conditions is emphasized throughout the discussion.
pavel329
1. Solve the following recurrence relation.
an - 5an-1 + 6an-2 = 0, n ≥ 2, a0 = 1, a1 = 3
3. My attempt
I changed it to 0 = tn - 5tn-1 + 6tn-2
Don't know where to go from there.
Do you see something you can factor out of that polynomial?
I'm not sure how to factor anything with (n-1) or (n-2) as an exponent.
The book turned a similar equation into t2-t-6.
Which made no sense to me.
First factor out t^(n-2). It divides all three terms, right?
Ok so I now have it down to
t=2,3.
Now I assume i need to put that into an equation for the original problem.
Which I have no clue how to do.
But where does the n≥2 stand?
Does that affect my final outcome?
t=2,3.
Are you sure you've seen examples of this before? They should have given you one before they gave you this problem. The t=2,3 tells you the solution is a_n=A*2^n+B*3^n. You know a0 and a1. Use those to find A and B.
I've only seen one example.
sn = sn-1 + 6sn-2, s0 = 4 s1 = 7
However this equation put a 0 in place of the an and added the n≥2.
Which maybe I shouldn't have paid attention to.
But my final answer is: A=1 B=0. So an = 3n. Is this correct?
It sure is.
Dick said:
It sure is.
Thank you very much for your help.
