Solving a problem with Monotonic convergence.
  • Thread starter Disowned
    Convergence
Disowned
I have a problem that states that An = [tex]\sqrt{A_{n-1}}[/tex]
, N is [tex]\geq[/tex] 1 where A0 is a positive constant.
I have to show that the sequence
{An} is decreasing if A0 > 1 and increasing if A0 < 1.
Show that the sequence is bounded below if A0 > 1 and bounded above
if A0 < 1.
Also I have to show the limit as n [tex]\rightarrow\infty A_n = 1[/tex]
Now I'm pretty sure that I am right so I just need some verifcation here. This is what I did:
A0 = [tex]\sqrt{A_{1-1}}[/tex] = [tex]\sqrt{A_0}[/tex]
[tex]\sqrt{A_0}[/tex] < A_0[/tex]
A0 < (A0)2
Call A0 = F(n)
F(n) > 1
F(n) = [tex]\sqrt{2}[/tex]. F(n) < N [[tex]\sqrt{2}[/tex] < 2]
F(n) < 1
F(n) = [tex]\sqrt{1/4}[/tex]. F(n) > N [[tex]\sqrt{1/4}[/tex] = 1/2 > 1/4]
So {An} decreases if A0 > 1 and increases if A0 < 1.
Because of the behavior of An in relation to N, An will always be less than N itself. If An > 1 and will be bounded below N.
Likewise if An An < 1 An will be greater than N and will always be bounded above.
3.
n [tex]\stackrel{Lim}{\rightarrow}[/tex][tex]\infty[/tex] |[tex]\sqrt{A_n/A{n-1}}[/tex] = 1
Via the ratio test.
So, is this a valid approach or am I off?
if A0 < 1.
You mean A1 is equal to [itex]\sqrt{A_0}[/itex]
[tex]\sqrt{A_0}[/tex] < A_0[/tex][/quote]
This is only true if A0> 1. There are two different problems here, A> 1 and A< 1, and you need to distinguish between them.
A0 < (A0)2
Call A0 = F(n)
I presume you mean An[/sup]= F(n). Other wise there is no "n" in F(n).
F(n) > 1
If you are dealing with the "A0> 1" case, F(0)> 1 and you need to prove this for other n.
What? Even assuming you mean A0, you are not given this!
F(n) < 1
Okay, I assume you are now doing the other case.
You have not proved that. Do so.
3.
Via the ratio test.
I would recommend using "proof by induction".
Okay based on what you are saying, If I rewrite the first part of the problem like this
A1 = [tex]\sqrt{A<sup>0</sup>}[/tex]
And then write that this infers that A0 > A1
I could then say A0 > 1 ?
Then use that inequality to prove N > 1 by comparing An-1 > An?
Saying n -1>n would lead to n > n +1.
From there I guess using An = F(n) would be okay?
