Solving a problem with the shell method
  • Topic:
  • Thread starter Thread starter Petrus
    Method Shell
11 replies · 3K views
Petrus
Hello MHB,
Consider the region bounded by the lines $$x=0$$,$$y=1$$ and curve
$$y=\sin(x)$$, $$0\leq x \leq \frac{\pi}{2}$$ decide the volume when it rotate in y-axe ( Tips: $$t=\sin^{-1}(y)$$ can be usefull)
I got pretty confused what my integral limit shall be. I know the formula will be
$$\pi\int_a^b xf(x)^2 $$.
Regards,
$$|\pi\rangle$$
Re: shell method
The formula you have cited pertains to the disk method. After having sketched the region to be rotated, I find the volume of an arbitrary shell is:
$$dV=2\pi rh\,dx$$
where:
$$r=x$$
$$h=1-\sin(x)$$
However, given the hint you have included, I suspect you are to use the disk method instead. What is the volume of an arbitrary disk?
Re: shell method
$$dV=2\pi rh\,dx$$
where:
$$r=x$$
$$h=1-\sin(x)$$
Hello Mark,
$$\int_a^bf(x)^2 = \int_a^b\arcsin^2(y)$$ I am still kinda confused what our limit shall be
Regards,
$$|\pi\rangle$$
Re: shell method
You have left off the differential from your definite integrals, which is the thickness of the disks, and will tell you with respect to which variable you are integrating, and thus, what your limits need to be. The volume of an arbitrary disk is:
$$dV=\pi r^2\,dy$$
where:
$$r=x=\sin^{-1}(y)$$
hence:
$$dV=\pi\left(\sin^{-1}(y) \right)^2\,dy$$
So, what values does $y$ have in the summation of the disks?
Re: shell method
MarkFL said:
You have left off the differential from you definite integrals, which is the thickness of the disks, and will tell you with respect to which variable you are integrating, and thus, what your limits need to be. The volume of an arbitrary disk is:
$$dV=\pi r^2\,dy$$
where:
hence:
Hello Mark,
If I have understand correctly, to get our y limit we got our x limit which is $$0\leq x\leq\frac{\pi}{2}$$ so our y limit will be $$\sin(0)=0$$ and $$sin(\frac{\pi}{2})=1$$ that means $$0\leq y\leq1$$ and about forgeting "dy" is something really bad cause I always think that in my and never write it up...
Regards,
$$|\pi\rangle$$
Re: shell method
Yes, those are the correct limits of integration:
$$V=\pi\int_0^1\left(\sin^{-1}(y) \right)^2\,dy$$
How do you think you should proceed?
Re: shell method
Hello Mark,
I would do as they gave the tips. $$t=\sin^{-1}(y) $$,$$\sin(t)=y <=> dy=\cos(t)dt$$ for the limit $$y=0 <=> t=0$$ and $$y=1 <=> t=\frac{\pi}{2}$$ so we got
$$\pi\int_0^{\frac{\pi}{2}}t^2\cos(t)dt$$
is this correct?
Regards,
$$|\pi\rangle$$
Re: shell method
Yes, that is correct! (Yes)
Re: shell method
Hello Mark,
First I want to thank you for taking your time and helping me!:) I have correctly integrate ( for those who is interested you will have to use integration by part twice) but I am interesting on the method you posted #2 I don't se how you get $$h=1-sin(x)$$ the answer is $$\frac{\pi(\pi^2-8)}{4}$$ I would like to solve this problem with disc method as well.
Regards,
$$|\pi\rangle$$
Re: shell method
Using the shell method, and referring to your sketch of the region to be revolved about the $y$=axis, can you see that the height of an arbitrary shell is the distance between the upper bound $y=1$ and the lower bound $y=\sin(x)$, and since on the given interval we have $\sin(x)\le1$, this distance is $1-\sin(x)$.
Re: shell method
Hello Mark,
this lead me to another question so basically on what we did early our upper bound is $$\sin^{-1}(y)$$ and our lower bound is $$y=0$$ right? I think I did not understand that early but is this correct?
Regards,
$$|\pi\rangle$$
Re: shell method
The bounds for $x$ are actually stated in the problem:
$$0\le x\le\frac{\pi}{2}$$
