Solving a Second Order Differential Equation with Complex Roots
  • Thread starter gonch76
    2nd order
gonch76
I have put down the whole question and my answers which i would appreciate if someone could comment:
Part 1.1
Find the general solution of the equation (d^2 z)/(dx^2 ) - 4 * dz/dx + 13z = 0
Put into form: a * m^2 + b * m + c
∴ m^2 - 4m + 13 = 0 a = 1, b = -4, c = 13
Then:
m_(1,2 = (-b±√(b^2-4ac))/2a)
∴m= (-(-4)±√(〖(-4)〗^2-(4*1*13)))/(2*1)
∴m= (4±√(16-52))/2
∴m= (4±√((-36)))/2
∴m= (4±6j)/2
∴m= (2 (2 ±3j))/2 Note: the 2’s cancel
Then
e^(∝x )* (Acos (βx)+ Bsin (βx) )
∝ =2
β=3
∴ z(x)= e^(2x )* (Acos (3x)+ Bsin (3x) )
Part 1.2
Find the particular solution of the form u(x)= C* e^2x
for the differential equation (d^2 u)/(dx^2 ) - 4 * du/dx + 13u = 〖27e〗^2x
∴u(x)= C* e^2x du/dx=C* 〖2e〗^2x (d^2 u)/(dx^2 )=C* 〖4* e〗^2x Note: 27 is ignored as it is a constant
Then replace:
∴ C*4* e^2x + (- 4) * C * 〖2e〗^2x + 13 * C * e^2x=〖27e〗^2x
∴ C*e^2x * (4 + (-8) + 13)=〖27e〗^2x Note: e^2x cancel out
∴ C*9=27 ∴ C=27/9 = 3
Substituting ‘C’ into the equation gives:
∴ u(x)= 3 * e^2x
Part 1.3
Find the general solution of the differential equation (d^2 u)/(dx^2 ) - 4 * du/dx + 13u = 〖27e〗^2x
General solution when the equation is equal to zero + the particular solution = general solution when equation equals the same value as the particular.
The general solution can be expressed as: y(x)= u(x)+ z(x)
∴y(x)= 3 * e^2x + e^(2x )* (Acos (3x)+ Bsin (3x) )
Note: I believe that the above equation ((d^2 u)/(dx^2 ) - 4 * du/dx + 13u = 〖27e〗^2x) is meant to be dy/dx, not du/dx.
any comments gratefully received.. Cheers.
Looks good to me. (I didn't check your calculations really closely, so it's possible there's an algebra mistake lurking in there.)
correct.
and you should stick to only y(x), z(x), or u(x) in the ODE if it stays the same ;)
