Solving a Simple Pendulum Problem with Math
9 replies · 4K views · last reply
Lord Anoobis
A 100g mass on a 1.0m long string is pulled 8.0 degrees to one side and released. How long does it take for the pendulum to reach 4.0 degrees on the opposite side?
##T = 2\pi \sqrt\frac{L}{g}##
##x(t) = A\cos\omega t##
From the simple pendulum we get ##\omega = \sqrt\frac{g}{L}## which leads to:
##x(t) = A\cos\sqrt g t##
##A = 8.0## and ##x(t) = 4.0## can be substituted directly since it results in the cosine of an angle then:
##\cos\sqrt g t = -0.50##
##t\sqrt g = \frac{4\pi}{3}##
##t = 1.3s##
Which happens to be twice the actual answer. The only possibility for error I see is ##\arccos(-0.5)##.
What I don't see is why. My reasoning was that since we're looking at 4.0 degrees on the opposite side, the angle must be the second point where cosine is negative, ie. ##\frac{4\pi}{3}##. What am I missing here?
You need to be careful working in degrees.
I think you've identified the error. How did you evaluate the inverse cosine?
PeroK said:
Why are you working in degrees?
Because in this case it makes no difference since the division results in a dimensionless figure.
Yes, but I'd be careful. It's an easy way to go wrong. If you draw a graph of cos, you'll see where you've gone wrong.
There are two possibilities for ##-0.5##, either ##\frac{2\pi}{3}## or ##\frac{4\pi}{3}##. I took the first figure to equate to 4.0 degrees on the side on which the swing started.
Wouldn't that be where ##cos = 0.5##?
I'm sure that's not the case.
Are you sure you're sure?
Can you say where the pendulum is when?
##cos(\omega t) = 1##
##cos(\omega t) = 0.5##
##cos(\omega t) = 0##
##cos(\omega t) = -0.5##
##cos(\omega t) = -1##
(All for the first time)
I just noticed there's a typo in my initial post. It's supposed to be ##x(t) = -4.0## That's where the negative sign comes from.
I see what you mean here. The pendulum in question hasn't even completed one half of a full cycle. ##\frac{4\pi}{3}## is when it reaches 4.0 for the second time.
