Solving a Tricky Physics Pulley Problem: Finding M2 with Tension and Mass M1
37 replies · 6K views
soolights
<Mentor's note: moved from a technical section, therefore no template>​
hey guys, i have a question about a tricky physics 1 problem our teacher gave us today, paraphrased as follows:
there is a mass M1 on a flat, frictionless horizontal table connected to a pulley, and on the other side of the pulley is another mass M2 the pulls downward (off the table). the system is frictionless. the tension of the string is T and the mass of the table mass is M1, so what is M2 in terms of M1 and T?
we have a test soon and i would really appreciate help :/
You can use Newton's Laws to find an Solution.Draw a free body diagram for each object then equal them to the net force.I can try to help you If u give me something.You should try to do it yourself a bit at least
Arman777 said:
You can use Newton's Laws to find an Solution.Draw a free body diagram for each object then equal them to the net force.I can try to help you If u give me something and this looks like homework question.You should try to do it yourself a bit at least
i don't understand how to list these out with so few information. there's nothing given for acceleration, movement, or relationships between anything...?
If you think there's no friction and both ##M_1## and ##M_2## are not moving..thats impossible I think.Does ##M_1## makes a circular motion ?
Arman777 said:
If u think there's no friction and both ##M_1## and ##M_2## are not moving..thats impossible I think.Does ##M_1## makes a circular motion ?
yes i made a mistake, we don't know which way it moves
Whats this means ?
Ok I think ##M_1## makes a circular motion.If there's no friction this is the seems only possible way.Now What forces acting on ##M_1## and what's the total force on acting on ##M_1## ?
no, it doesn't make a circular motion. we just don't know the acceleration of the system. everything is linear! (these problems should be solvable without a calculator)
the tension force is acting on M1 and pulling it toward the edge of the table, along with the gravitational weight force and normal force from the table. the net force for M1 is the tension force.
Ok,I understand,Now the idea is the Net force acting on the object should be equal the total force.and
##\vec F_{total}=m\vec a## can you find an equation for M1 using this ?
##\vec F_{total}=m\vec a## can u find an equation for M1 using this ?
fnet = ma, so m = fnet/a? i don't know if this will help or not because it doesn't provide acceleration :/
As you said there's Tension acting on the Object, that's the net force , and this net force should be equal to Total force so...?
so the only force is the tension...but how does that link to the mass of m2 hanging off the table? m2's only force is the tension force holding it up..
If M2 is pulling downward off the table, don't you already know its acceleration?
oh gosh! since there's no friction and it pulls downward, it's just 9.81. fnet = t, so using fnet = ma, m2 = t/9.8?
Nidum said:
Sorry but that is not correct .
Draw a diagram and show what forces are acting on m1 and m2 .
this is the FBD I've been using--
I am trying to that...M1 has T (thats the net force) and that's equal to M1a (total force) so,T=M1a.
You have to do this M2
there's two forces acting on M2
so, for tension and weight..?
Nidum said:
Your diagram does not really show the forces acting .
i'm not sure what else there is to put...normal, tension, gravitational forces are all there and i don't know of any other ones that are applicable?
yes,try to do what I did for M1
okay, so force in the y direction is both tension and gravity, so fnet = w-t (is necessarily w>t?). so w-t = m2a?
Arman777 said:
yep correct
so m2a = w-t, how to get rid of w?
Arman777 said:
Whats w ohh I assume you know that.Thats the weight of the m2
OK let me try again lol this isn't going too well for me is it
m2a = w-t
m2a = m2g-t
m2a-m2g=-t
m2(a-g)=-t
m2=-t/(a-g)
The questions ask you to find m2 in terms of T and m1.You have 2 equations as I said.Get rid of a.
oh, i missed that message, sorry
T=M1a , a = T/M1
M2g-T=m2a ,
M2g-T=M2(T/M1)
