Solving a trigonometry equation simultaneously in two variables
The discussion revolves around solving the trigonometric equations sin(x+2y)=1/2 and cos(2x-y)=1/√2 simultaneously. Participants suggest methods for obtaining general solutions for x and y, emphasizing the importance of considering multiple angles for sine and cosine functions. The conversation highlights the need to manipulate the equations algebraically to eliminate variables and derive solutions. Ultimately, a participant confirms they found the correct answers as indicated in their textbook. The thread illustrates the collaborative effort in tackling trigonometric equations and the nuances of general solutions.
PhysicsKid703
Solve the equations sin(x+2y)=1/2 , cos(2x-y)=1/ sqrt(2)
I tried getting a generic solution for both the first and second equation. How do I further proceed? By simultaneously solving? I so, how?
2x-y=2m*pi + or - pi/4
x+2y=n*pi + (-1)^n * pi/6
Yes, solve those two equations simultaneously. For example, if you were to multiply the first equation by 2, getting 4x- 2y= 3m\pi\pm \pi/2. Now, adding that to the second equation eliminates "y" from the equation.
You seem to be saying you do not know how to solve the two equations
2x - y = a\\x + 2y = b
for ##x, y## in terms of ##a,b##. Is that really true, or have you just not 'recognized' the problem correctly?
I'm in 11th grade, doing IIT pre-prep as extra classes.
I do know how to solve simultaneous equations :P. However, I was wondering whether the +- part would affect solving simultaneous equations, because I want a general solution for x and y e.g. n*pi + pi/4 or something.
Well, yes, it will 'affect' the answer but the way the answer is affected is just basic algebra. Have you done as I suggested?
i am not sure but i think we can solve it
as
(x+2y)=sin(inverse)1/2=30(degree)
2x-y=cos(inverse)1/sqrt2=90(degree)
amusing 1 and 2 equation
multiply 2 equation by 2
then we will get x=24(degree)
and y=3(degree)
Welcome to PF;
as
Well spotted.
The thing is that sin(a)=1/2, not just for for a=30°, but also for a=150° and many other angles besides. In degrees, the full equation goes like:
##a = 180n + 30\times (-1)^n: n=0,1,2,3,\cdots##
This is what is in post #1, with a=x+2y (right at the bottom) - except that PhysicsKid703 is using radians instead of degrees.
Hmm.
Ok HallsofIvy, I understood what you said and I got the answer written in the back of the book. Thanks so much for the help.
SimonsBridge- Yes, that's the general equation for all the values of theta when sin theta = sin alpha. Thats in fact exactly how it appears as a formula in my text.
Did you understand where that relation came from?
I was thinking that you could use the same sort of observation to get rid of the ##\pm## for the cosine part. Just look at the series of values of "a" that make cos(a)=1/√2 true and try to express them using the (-1)^n style of notation. (hint: 2n-1 is always an odd number for n=1,2,3...).
But you managed to get the "correct" answer anyway so... well done :)
