Solving an Euler differential equation
member 587159
Solve the differential equation ##(2x+1)^2y'' + (4x+2)y' - 4y = x^2##
Can someone verify whether my solution is correct?
We perform the substitution ##t = \ln|2x+1|##. Then, ##e^t = |2x+1|## and ##x = \pm(e^t -1)/2##
Without loss of generality, let's solve the equation for ##x = (e^t-1)/2##. (the other case is analogue)
We find ##\frac{dy}{dx} = 2e^{-t}\frac{dy}{dt}##
##\frac{d^2y}{dx^2} = -4e^{-2t}\frac{dy}{dt}+4e^{-2t}\frac{d^2y}{dt^2}##
Hence, the differential equation becomes:
##16y'' - 16y = (e^t-1)^2##
This is a linear differential equation with constant coefficients:
The homogeneous is given by:
##y_h = c_1e^t + c_2e^{-t}##
Let's apply variation of the constants to find ##y_p##, the particular solution.
##y_p = c_1(t)e^t + c_2(t)e^{-t}##
Then, we can find the functions ##c_1'## and ##c_2'## as solutions of the system:
##\begin{cases}c_1'(t)e^t + c_2'(t)e^{-t} = 0\\c_1'(t)e^t - c_2'(t)e^{-t} = (e^t-1)^2\end{cases}##
##\iff c_1'(t) = -c_2'(t) = \frac{(e^t-1)^2}{2e^t}##
Hence:
##c_1(t) = e^t/2 - t - e^{-t}/2 = -c_2(t)## (if we set the constant of integration to ##0##)
Hence, the solution is given by:
##y = y_p + y_h = c_1e^t + c_2e^{-t} -1 + 1/2e^{2t}-te^t + 1/2e^{-2t}+te^{-t}##
And by substituting back:
##y(x) = c_1(2x+1) + c_2\frac{1}{2x+1} + \frac{(2x+1)^2}{2} - \ln(2x+1)(2x+1) - 1 + \frac{1}{2(2x+1)^2} + \frac{\ln(2x+1)}{2x+1}##
Hence:
What is preventing you from putting your formula for ##y(x)## into the DE to test if it works?
This doesn't look right.
What a pity that last LHS term is –4y instead of 4y, in which case the LHS would have been an exact second derivative. Sure you copied it out right.? :oldsmile:​
I just checked and I made no typo, unfortunately.
Pity they didn't ask good question. I can't see any way to hammer that one into something so nice. :biggrin:
