Solving an inverse trig equation
  • Thread starter Thread starter Kaylee!
    Inverse Trig
To solve the equation arcsin(2x) + arccos(x) = π/6, the first step involves isolating arcsin(2x) and applying the sine function. This leads to the equation 2x = sin(π/6 - arccos(x)), which can be simplified using the sine difference identity. A right triangle is constructed to determine the values of sin(arccos(x)) and cos(arccos(x)), resulting in the equation 2x = (1/2)x - (√3/2)√(1-x²). After manipulating the equation, it is concluded that x must be negative, as the right-hand side is negative while the left-hand side is positive for positive x values. The solution process highlights the importance of considering the signs of the terms involved.
Kaylee!
Solve for x
arcsin(2x) + arccos(x) = \frac{\pi}{6}
Subtracting arccos(x) from both sides and then taking the sine of both sides:
2x = sin\left[\frac{\pi}{6} - arccos(x)\right]
Applying the difference angle identity for sine:
2x = sin \frac{\pi}{6} cos[arccos (x)] - cos \frac{\pi}{6} sin [arccos (x)]
We can draw a right triangle with a hypotenuse of 1, angle opposite of theta of \sqrt{1-x^2}, and angle adjacent to theta of x. From this triangle we can deduce the values of cos( arccos(x) ) and sin( arccos(x) )
2x = (\frac{1}{2})x - \frac{\sqrt{3}}{2}{\sqrt{1-x^2}}
Multiplying each side by 2, subtracting x from each side, squaring each side, and then dividing each side by 3
3x^2 = 1 - x^2
Adding x^2 to each side, and then dividing each side by 4
x^2 = \frac{1}{4}
At this point I need to take the square root of each side. I know it's the negative from trying each out, but how do I show this algebraically?
When you say 2x = x/2 - sqrt(3)/2 sqrt(1-x^2)...
3x = -sqrt(3)sqrt(1-x^2).
But since sqrt(1-x^2) is positive, the RHS is negative, which is true iff the LHS is negative, which is true iff x is negative, so x must be negative.
