Solving Circuit Board Problem: 18vdc Motor, 8 Ohm Resistor
  • Thread starter Thread starter jhendren
    Board Circuit
The discussion revolves around troubleshooting a circuit involving an 18V DC motor, an 8-ohm resistor, and a capacitor, aimed at powering a universal charging mat. Participants explore the configuration of components and their effects on circuit functionality, addressing issues related to voltage output and component placement.
  • Experimental/applied
  • One participant describes a circuit with an 18V DC motor, a switch, an 8-ohm resistor, and a capacitor, seeking help with voltage output issues.
  • Another participant suggests that capacitors do not pass DC and recommends removing the capacitor from the circuit.
  • A participant mentions that the motor is rated for 1.96 amps and questions the effectiveness of using an 8-ohm resistor.
  • Discussion includes the idea that the capacitor should be placed in parallel with the load rather than in series, as it serves to stabilize the DC output.
  • Some participants express uncertainty about the correct orientation of the capacitor and its role in the circuit.
  • There are suggestions to measure voltages across components to diagnose issues, and to consider the possibility of faulty wiring.
  • One participant notes that the motor slows down when the charging mat is connected, indicating some power generation.
  • Another participant questions the adequacy of the capacitor size and suggests that a larger capacitor or alternative power sources might be more effective.
  • A participant reports success in getting the circuit to work but does not provide details on the specific changes made.
Participants express differing views on the placement and necessity of the capacitor, with some advocating for its removal while others emphasize its importance in the circuit. The discussion remains unresolved regarding the optimal configuration and effectiveness of the components used.
There are mentions of fluctuating voltages and the need for clearer circuit diagrams, indicating potential limitations in understanding the circuit's behavior. The discussion also highlights the importance of measuring current and voltage accurately to diagnose issues.
Individuals interested in circuit design, troubleshooting electrical components, and those working with DC motors and power supplies may find this discussion relevant.
jhendren
I'm having issues with this simple circuit. If you look in the top left corner of the image attached, I have a dremel tool powering an 18vdc motor which puts out current at 1.96 amps. Then it goes to a switch. The wires then go to an 8 ohm resistor(white rectangle) then to a 4700μF capacitor(blue cylinder). Now where the pencil is in the picture, I still have 18 volts being regulated by the capacitor. Where I have soldered the ground wire from the switch and the hotwire to the capacitor I still get 18 volts. There is a connector at the end of the black wire at the bottom right that plugs into a universal powermat, and I cannot get 18 v out of the end to power the mat. Can anyone help me?
You seem to have a DC motor with a capacitor and a resistor in series with it, fed from an 18 V DC supply.
Capacitors do not pass DC, so the motor will not work like that.
So, you can remove the capacitor (replace it with a piece of wire) and try again.
It did not work. I know the specs require 18 v at 1 amp to power the charge mat, and the motor is 18v at 1.96 amps. I have used an 8 ohm resistor and a 10 ohm resistor as well, any other suggestions?
If I'm reading this right, vk6kro seemed to be hinting that you need the capacitor in parallel with the load, not in series. I'd agree with him.
The capacitor is a filter. Put it *between* the V+ and return line, and it blocks DC from shorting to ground, but allows the ac component to bleed to ground (=stabler DC). If you put it *in* the return line, it blocks all DC current from going through the circuit (but you'd still read a V+ *potential* as you noted)
The most important function of the resistor is to prevent an initial short-circuit through the capacitor as it charges. That would burn out your generator motor.
alright, I'll go try this. I'll post again in about an hour or so
Leave the capacitor out anyway.
Re-reading your post, are you using the motor as a generator to provide power to charge up other devices?
This would be a way of converting 12 volts DC (which powers a Dremel tool ) to 18 volts DC
If you have 18 volts at one end of the output wire and not at the other, then maybe you have a faulty wire?
Can you measure the voltages relative to the shield on the output cable? With the capacitor removed, what voltage do you get on each side of the resistor, again, relative to the shield on the output wire?
The dremel tool is spinning a small dc motor at max rpm to produce 18volts at 1.96 amps. The motor is meant to power the universal charge mat
The voltage was fluctuating on both sides of the resistor
Here's a closeup of it redone
Here's the closeup in parallel
The capacitor is still wrong.
It should go across the output, ie from the centre of the output wire to the shield of the output wire.
Note that the + sign on the capacitor has to go to the + side of the supply.
I can't contain my curiosity -- why are you building this device?
vk6kro I am relatively new to circuits, could you please explain what you mean by the shield of the wire?
The wire in your photo looks like shielded wire. This is a central wire surrounded by a woven shield of copper wire.
This is called a shield as it stops interference reaching the central wire if it is grounded.
It may have more than one insulated wire inside the shield which makes it a little different to coaxial cable, which normally only has one conductor inside the shield.
It is usually not needed for power wiring, as in this case, but it can be used if you have it on hand.
Why are you not taking the point about the Capacitor? It will never work with a Capacitor in series. Deal with the most important issue first then move on if it still doesn't work.
Centaur,I thought by soldering the resistor and capacitor at the same point makes it in parallel?
Sorry, the last picture has them in parallel. But are you sure you have the capacitor connected the right way round? I can't tell, from the picture, which is positive and which is negative but the capacitor mustn't be connected the wrong way round. What's it there for anyway?
But, without a more detailed 'schematic' diagram, it's hard to see what you are actually doing. It would be normal to supply a diagram such as you see in most other posts, making clear what is what. How are you testing whether there is any current coming from the motor generator? What is the purpose of the Capacitor and the power resistor? What voltage does the motor actually provide when the power mat is connected across it? Where did you get the info about the current that the motor can supply?
I wonder whether your motor can, in fact, provide enough power to warm up the mat. You could get a clue by observing how the pitch of the motor changes when the mat is connected. If any power is being delivered, the motor should slow down audibly.
Why not just connect the motor straight to the mat and see if it warms up?
The motor does slow down audibly, I noticed that a few days ago, I also need to place the switch after the capacitor and resistor. I believe that the current will fluctuate, so having the capacitor drain and power the mat steadily is my goal. However, I am not quite sure how long(if it even can) the capacitor can support the mat. But the capacitor is 4700μF and the resistor is 8 ohms. I have tried series and parallel and it seems the paralle works best.
The diagram doesn't include where you have connected the heat mat (fairly important). Also, the two way switch would appear to apply a short circuit to the motor output if you put both contacts the other way. Have another look and try to improve the circuit diagram. We could be almost there!
Also, it's nice that the motor slows down. That implies some power is being generated and dissipated (somewhere). Does the resistor get hot?
That 100k resistor is much too high to achieve anything, btw.
You should have something like this:
http://dl.dropbox.com/u/4222062/Generator%20with%20filter.PNG
A 5000 uF capacitor is not really very big and it won't power anything for long.
At best, it will remove some minor variations in the output of the generator.
I think the power mat is a charging board that looks a bit like a skate board, so it won't take a huge current.
However, powering it like this is not the way to go. You could look for an old charger from a laptop. Many of these put out 18 volts DC.
I got it to work
How warm does the heat mat get?
It should do better with no series resistor. But you really need a meter for this.
i have a control technique drive type UNI 4401 , 45 KW
can i obtain the circuit diagram of the two internal boards ( UD45 ISS.1 , UDISS.2 ), and also the wiring diagram of this drive ?
This looks like a new topic. Please start a new thread.
  • · Replies 19 ·
28K
