Solving differential equation involving initial value?
The discussion focuses on solving the differential equation dy/dt = y - 5 with the initial condition y(0) = y0. Participants clarify that the equation can be rearranged into a separable form, allowing integration. One method discussed involves using an integrating factor, while another emphasizes the simplicity of separation of variables. The correct solution is derived as y = 5 + (y0 - 5)e^t, with the constant C identified as y0 - 5. The conversation highlights the importance of recognizing the equation's separability for easier resolution.
Chandasouk
dy/dt = y-5 , y(0) = y0
The general form for first ODE has to resemble this
dy/dt + p(t) = g(t)
so I moved the y over to the left side of the equation
dy/dt - y = -5
I think this is where I screw things up. It's not really in this form dy/dt + p(t) = g(t) but rather dy/dt - p(t) = g(t).
Regardless, I went to find an integrating factor \mu(t) = e\intp(t)dt
which gave me e-t as my \mu(t). You then have to multiply that to both sides of this equation
dy/dt - y = -5
Is my procedure correct so far? Because I cannot get the correct answer which is
y=5+(y0-5)et
dy/dt + p(t) = g(t)
dy/dt - y = -5
dy/dt - y = -5
y=5+(y0-5)et
I'm not sure you wrote the problem correctly. You have dy/dt - y = -5 but y is not of the form p(t).
I get y=\frac{5t+y(0)}{1-t}
Well, that's wrong. The solution is an exponential. You can probably get it with an integrating factor. But it's a lot easier if you just realize the equation is separable.
I actually am behind two lectures because I switched into a new math section, so could you show how to do it with integrating factor?
There's no need. Just take the initial and divide both sides by (y-5). Then you have something integrable.
To elaborate on what Char. Limit said, separate the original equation like this:
\frac{dy}{y - 5} = dt
Now integrate both sides.
I took the integral and got
ln(y-5) = t+c
taking e of both sides gives
(y-5) = et+C
I do y(0) = y0 =(y-5) = et+C
How do I get my C term?
ln(y-5) = t+c
(y-5) = et+C
You can write e^(t+C) as C*e^t since C is an arbitrary constant. So put t=0 and y=y0 into y-5=C*e^t. What's C?
Thanks, Dick. I wasn't aware that you could rewrite it that way. I'll have to keep that in mind. C is then y0-5
e^(x+C)=e^C*e^x. Since C is arbitrary you may as well just call e^C the arbitrary constant and write it C*e^x.
