Solving Diophantine Equation: 97x+35y=13
  • Context:
  • Thread starter Thread starter Petrus
24 replies · 5K views
Petrus
Hello MHB,
I got problem with this http://staff.www.ltu.se/~larserik/applmath/chap10/part4.html (It's 'Exempel 1' and yes it's on Swedish), I follow my book method and get,
$$x=169-35K, \ y= -468-97K$$
I get the 'homogen soloution' that $$x=-35k, \ y=97k$$
'Solve equation $$97x+35y=13$$'
Regards,
Mathematics news on Phys.org
Petrus said:
Hello MHB,
I got problem with this http://staff.www.ltu.se/~larserik/applmath/chap10/part4.html (It's 'Exemple 1' and yes it's on Swedish), I follow my book method and get,
Regards,
Erm... what is your question?
ehmm. I am suposed to find one soultion with gcd, eucliders algoritmen then find all other soloution, cause it got infinity soloution, for x and y. Do it make sense now?
Regards,
Regards,
Ah, okay.
So do you know how to apply Euclid's algorithm?
(Btw, isn't this university-level stuff instead of pre-algebra?)
Good call...moved to the Number Theory sub-forum.
I like Serena said:
Ah, okay.
Yes, I get x=169 and y=-468
That looks about right.
Wolfram says x=29, y=-80, which is effectively the same answer.
(Since you can add a multiple of 35 to x if you also subtract the same multiple of 97 from y.)
So you're all good?
So you're all good?
so this answer is correct?
cause that website says the answer shall be
http://staff.www.ltu.se/~larserik/applmath/chap10/eq409.gif
The website answer is correct. If you add a multiple of 35 to $x$ then you have to subtract that multiple of 97 from $y$.
I am kinda confused cause I follow the method from my book.
* find a soloution $$x=x_0 , y=t_0$$ (particulate solution) that is what we find we euclidmens algorithmen.
*Find all soloution to homogeneous equation $$ax'+by'=0$$ and that is the one i do it wrong then...
The solution is $x'=kb,\ y'=-ka$, for integers k (note the minus sign).
Substitute to verify...
that is the part I strugle, my book say $$x'=-kb, \ y'= ka$$
I like Serena said:
That works as well.
Can you substitute that solution in the equation?
$$x' = -35k , \ y'= 97k$$
I like Serena said:
Yes.
Can you substitute that in the equation $ax′+by′=0$?
$$35(-35k)+97*97k=0$$ ?
I like Serena said:
I kind of lost track of the equation. :)
But the equation was $97x'+35y'=0$.
Can you redo the substitution with this equation?
$$97(-35k)+35*97k$$
my book says $$x=x_0+x' , y=y_0+y'$$
and our $$x_0=169$$ and $$y_0=-468$$
I like Serena said:
Do you see that this is zero?
Yes,
I like Serena said:
Yes?
That means the answer is $$x=169-35K, \ y= -468-97K$$
Petrus said:
$$97(-35k)+35*97k$$
Erm.
You have $x'=-35k,\ y'=97k$ and $$x_0=169$$, $$y_0=-468$$
If I substitute that into $$x=x_0+x' , y=y_0+y'$$, I get
$$\qquad x=169+(-35k) , y=-468+(97k)$$.
See the difference?
I like Serena said:
Erm.
See the difference?
Finally, I did find my mistake...! I somehow did have $$-97k$$ in my paper... and confused myself..! Can you confirm that this is correct answer?
Erm, yes. It is the correct answer.
It's what the website solution said...
Hello I like Serena,
I am sorry I just got confused, Thanks for taking your time and now I understand diophantine equation a lot better! Hey look at the bright side, you gained some 'thanks' ;)
Regards,
